410 pistons in a 1974 390
Hey I bought a 1974 ford f100 2wd from my uncle with a 390 for the engine to rebuild, He bought it almost new and the motor has never been apart and when I got into the engine and looked at the pistons they said 410 on them and I compared them to another 390 truck piston and they were alittle different, The title on the 74 says 390 and the valve covers say 390 to.DID FORD EVER PUT 410 PISTONS IN A 390 ? OR IS IT POSSABLE IT IS A 410 ? OR AN ACCIDENT? THANKS
There should be a code on the crankshaft, "2U" for 390, "1U" for 428/410, etc... Find that and see what it says and post back here.
But yeah, I've heard of low-compression truck 390's coming with 410 pistons from the factory because it was the easiest way to get the compression WAY down... The higher pin height makes the piston sit lower in the bore.
check the crank, but...........
Check the crank, you never know if someone was in there, but yes, Ford used the 410 pistons with 390 rods and cranks to lower compression ratios in the pickup engines. Some of the earlier engines came with pistons that were actually mercury leftovers, then when they saw that they did what they wanted, they didn't change the outside of the mold. If you use the 1139 silvolite or sealpower 381p you will duplicate this problem when you rebuild, and if you use felpro 1040 gaskets you'll get 7.8 to 1 compression. Thankfully, we have better options now. Wanna know about them ? DF, and I really am at Dad's
WHERE is this located?
chiefsfootball
10-27-2015 08:44 AM
cws10190
09-09-2014 10:22 AM
mikeo0o0o0
08-17-2011 06:14 PM
67 428 Fairlane Ranchero
01-30-2003 08:12 PM
sgreen
01-26-2001 09:58 AM
