Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2008, 05:38 PM
1980StepSide 1980StepSide is offline
1980StepSide is starting off with a positive reputation.
M5R2 swap Throwout bearing question
I have been putting a new clutch into my engine/transmission assembly and I have a question about the throwout bearing. When measuring from the face of the transmission to the front face of the throwout bearing, it measures around 2 inches. When measuring from the back face of the motor, it's 3 inches to the clutch. Wouldn't this mean the throwout bearing is engaged all the time? Sorry in advance if this is a silly question, I've just now jumped into Fords from GM cars and didn't know if there is something different about M5R2 transmissions that I'm not realizing.
  #2 (permalink)
Old 11-06-2008, 06:41 PM
danr1 danr1 is offline
danr1 is gaining momentum as a positive member of FTE. danr1 is gaining momentum as a positive member of FTE.
New slaves are, from what I've seen, in the clutch fully "disengaged" position, bearing all the way out or forward when you get em, once installed it will quickly self adjust to the proper location in a couple of pedal pumps. Slightly backing away from the pressure plate fingers when you let off the pedal.
Read here,
All about Clutch
__________________
87, 94, 95 F250
89 Bronco II
05 Chevy Impala
  #3 (permalink)
Old 11-06-2008, 07:02 PM
Thank you for the input, I was worried something was wrong with it.
  #4 (permalink)
Old 12-19-2008, 04:09 AM
04mildodge's Avatar
04mildodge 04mildodge is offline
04mildodge is starting off with a positive reputation.
m5r2 swap
what did you have to do/get to put that tranny in the truck???
i want to put a manual in my truck. i hate auto's.
  #5 (permalink)
Old 12-19-2008, 03:34 PM
We just bolted it up to the engine and dropped it in. Since attach point for the crossmember is different, you have to get that loose and move it to where it fits on the frame rails. I just got my clutch master cylinder in the mail today so I'll be putting that in sometime soon. Mine was already a stick truck so the install on your's will be very different.
  #6 (permalink)
Old 12-20-2008, 04:51 AM
04mildodge's Avatar
well aside from the obvious stuff (clutch pedal assembly, slave and master cylinders and hydraulic lines) was there anything that i need to grab if i get it from a junkyard? ie the drive shaft or cross member? i appreciate your help...my last ford truck had what i wanted when i got it but it had too many issues and this one was cheap.
  #7 (permalink)
Old 12-20-2008, 05:31 AM
I haven't tried to fit up the driveshaft yet, but there weren't any issues with the distance from what I could tell. I had to use the mount from the old transmission since someone had cut the bolts off the one that came with the new transmission. You'll definitely have to move the crossmember. It looks like a huge pain to move the uppers that attach to it, so I might leave them off on mine.
  #8 (permalink)
Old 02-05-2009, 03:41 PM
04mildodge's Avatar
have you gotten yours on the road yet?
  #9 (permalink)
Old 02-05-2009, 05:31 PM
Not yet, just got to go through the wiring mess now. I've never worked on a diesel before so this part will probably be slow going. I was also in the middle of that Kentucky ice storm so that slowed down progress a bit too.
  #10 (permalink)
Old 02-05-2009, 05:34 PM
04mildodge's Avatar
let me know when it is complete and how it went....i just bought a m5r2.....
  #11 (permalink)
Old 02-05-2009, 05:36 PM
Not a problem, If you're just looking for a walk-through on the install, I can help you with that right now. My ignorance with diesels shouldn't slow down your project!
  #12 (permalink)
Old 02-05-2009, 05:45 PM
04mildodge's Avatar
well seing as i am in iraq....not slowing me down much lol.
  #13 (permalink)
Old 02-05-2009, 06:00 PM
Thanks for your service, military is something I've always regretted not going into. The swap is pretty easy and hurst makes a pretty slick shifter for the M5r2 that I'll be putting into my truck. The whole project is really easy once you lay it all out and get the transmission bolted onto the engine.
  #14 (permalink)
Old 02-05-2009, 06:10 PM
04mildodge's Avatar
hey no prob.....mine might not be so easy as i have a c6....which is a little longer then the m5r2...and is that shifter a short throw or just a cooler looking oe?
  #15 (permalink)
Old 02-05-2009, 06:23 PM
This is the listing in summit:
Hurst 3915025 - Hurst Billet/Plus Shifters - summitracing.com
Aside from the steering column, your swap should be similar since I didn't have a hydraulic setup to start with either.
Tags
4bt , 84 , adapter , dorman , kit , lowering , m5r2 , mount , plate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
