Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-06-2008, 01:31 PM
Ben34 Ben34 is offline
Ben34 is starting off with a positive reputation.
oil pressure gauge fluctuating
i have a 2000 f150 4.2 5 speed with 105k on it and recently i have noticed that the oil pressure gauge seems to rocking back and forth as i am accelerating through the gears. total movement is maybe 1/8" to 3/16". i know on my last f150 the fuel gauge was always acting up but i didn't know if this was an indicator of catastrophic falure or just a crazy gauge that has a loose ground or something. the engine never ticks or anything like it is out of oil or acts out of the ordinary otherwise. Any thoughts???
  #2 (permalink)
Old 11-08-2008, 02:38 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
If it does it when cold about the same as hot,I would suspect either the sending unit,or gage,if however it only does it after its at operating temp,you could have possibly a viscosity issue with the present oil,or a weak oil pump.
In either case unless the reading goes WAY South,Id say its ok.
You might try a different wieght oil.....
  #3 (permalink)
Old 11-08-2008, 05:32 PM
DirtStripHero's Avatar
DirtStripHero DirtStripHero is offline
DirtStripHero is starting off with a positive reputation.
Is this the stock gauge, or an aftermarket gauge? Because the stock gauge is basically a dummy gauge that really doesn't do anything unless you have zero pressure. An aftermarket gauge should do this. When you are accelerating the pressure will go up a little bit.
__________________
Michael
"If it has tits or wheels, It will give you trouble."
2000 F-150 4.2L, 5spd, 3.55, 4x4
1984 F-350 6.9L 2wd, T-19
1980 F-250 460, c6, 4x4, pulling truck
  #4 (permalink)
Old 11-10-2008, 10:12 AM
They are all stock gauges. it seems to be doing it when hot and cold. it's not normal fluctuation where it goes up when you are on the gas. It waves to me as I'm accelerating. As for the oil, it was just changed and came out of the same barrel as the last few oil changes so there should not be any issues there. I use valvoline 5-30 like i always have in the truck.
  #5 (permalink)
Old 11-10-2008, 10:53 AM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
I guess the important thing is to determine if it is an ACTUAL fluctuation in oil pressure or just an INDICATED fluctuation in oil pressure.
reference the second post in this thread:
http://www.ford-trucks.com/forums/21...ease-read.html
scroll down until you see "OIL"
hope it helps!
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #6 (permalink)
Old 11-10-2008, 11:31 AM
do you know if the number displayed in the diagnostic mode is the actual oil pressure?
  #7 (permalink)
Old 11-10-2008, 12:30 PM
BrianA's Avatar
Yes, I understand the actual oil pressure is indicated in "TEST" mode as described.
The oil pressure gauge is actually only an idiot light (go/no-go) hooked to a gauge instead of a light bulb.
here is a little more info......
Oil Pressure Gauge ... Or Is It?
I believe the number displayed in "TEST" mode is a reflection of actual oil pressure before it gets converted to a go/no-go signal.
edit: it is not the ACTUAL oil pressure. By that I mean your actual oil pressure will not be the numbers displayed, but the numbers dispalyed will be an analog representation of the actual oil pressure.
Make sense?
__________________
Brian A
  #8 (permalink)
Old 11-10-2008, 11:53 PM
Hey Brian, how hard would it be to hook up a real oil pressure gauge?
__________________
Michael
  #9 (permalink)
Old 11-11-2008, 11:24 AM
yea, the numbers in the diagnostic mode are "000" which is not the case. if so, it would have been ticking and stopped a long time ago. i have an oil pressure gauge i could nab off the race car for a little while but i don't know where on these engines i could hook it up to. Is there a plug somewhere i could tap into?
  #10 (permalink)
Old 11-11-2008, 11:54 PM
BrianA's Avatar
I have no personal experience connecting an aftermarket oil pressure gauge.
I do know there is a procedure for converting our idiot gauge into a true functioning oil pressure gauge. I don't remember the details but I seem to remember it was not very complicated.
As far as 000 showing, that comes as a surprise to me. I am pretty sure I have used it to check and seen numbers indicated. I'll try and remember to check tomorrow.
__________________
Brian A
  #11 (permalink)
Old 11-12-2008, 09:26 AM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, i have a machanical oil pressure guage that i fitted and i used a tee piece between the oil pressure sender and the pump. the guage is fastened on to the dash and the capilary copper pipe is fed thru a rubber grommet in the fire wall.
the job was straight forward and could have been made much easyer if i had take the drivers side wheel off to get to the oil pump/filter area.
for what its worth i think that your problem is the oil pressure sender. bokker.
Tags
01 , fluctuates , fluctuation , ford , gauge , oil , pressure , ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
