Fabtech lift & 7 lug rims
Old 10-03-2002, 10:42 PM
xbwfo's Avatar
xbwfo
xbwfo is offline
I own a '99 F-250 longbed (7 lug rims). Recently I lifted it with Fabtech spindles and put on the stock rims some 305/70/16 Pro Comp muds.
It still sits to low for me, so I want to add the Fabtech 3.5" Performance lift (coils & A-arms).
Fabtech's website states that you must use aftermarket wheels with a 4 3/4" backspacing to use this kit.
Is anyone using this lift kit with stock wheels and if so do your tires or rims have a clearance issue with the suspension?
Old 10-13-2002, 11:20 AM
Rand's Avatar
Rand
Rand is offline
Are they 7lug rims? or a 7lug cover.. covering 8 lugs?
no one makes aftermarket wheels for 7lugx150 as far as i can
research.
Rand
Old 10-14-2002, 03:43 PM
barn's Avatar
barn
barn is offline
the 7 lug pattern is just plastic, it's a hub cap. the actual wheel is underneath and it has an 8 lug wheel pattern
rjb
Old 10-17-2002, 07:53 AM
orange peel's Avatar
orange peel
orange peel is offline
Old 10-17-2002, 06:18 PM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
Post Fabtech lift & 7 lug rims
Nope, it's real. Another screwball Ford "Better Idea". The 2003 F-150 optional 7700# GVW package includes 16" 7-Lug Styled Steel Wheels. This payload package must have replaced the F-250 non-SD model.
GM uses 6 and 8 lugs on Silverado/Sierra trucks. Why does Ford have 5, 7 and 8? I doubt if Dodge or Toyota have seven either.
Jim
Old 10-18-2002, 12:13 AM
xbwfo's Avatar
xbwfo
xbwfo is offline
[updated:LAST EDITED ON 18-Oct-02 AT 01:15 AM (EST)] Well I answered my own question by putting the kit on. It works great except the camber is out of spec by 1.4 degrees positive (yes I put the camber adjuster cams in).
No clearance issues with 305/70/16 Pro Comp muds, they clear everthing by 3 inches easy.
I'm not sure why Fabtech notes that aftermarket wheels must be used with this kit. Maybe the 7 lug rims are offset enough to provide more clearance than 5 lug wheels are.
American Racing and Weld make 7 lug rims but all I have seen is 16 x 8's.
Blakshukvw
03-02-2017 08:41 PM
airbats801
1999 to 2016 Super Duty
02-16-2017 02:01 PM
BGDDYKWL
02-13-2017 03:50 PM
viperme
10-18-2016 03:22 PM
damonlan
1997 - 2003 F150
01-15-2003 11:36 PM
Quick Reply: Fabtech lift & 7 lug rims
