Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-05-2008, 01:01 PM
jarod17's Avatar
jarod17 jarod17 is offline
Nevada CL
jarod17 is gaining momentum as a positive member of FTE.
Smile 6 months to do this. Please advise.
My cousin has done it again. Another challenge. I have 6 months to put as much as I can into my truck. I know that to go with a turbo set up I need to work with a new exhaust and injectors to do this.
My questions are:
(1) What is the max CFM and boost psi I can run on my stock 460.
(2) What size injectors would be recommended.
(3) What would be a good header setup for here. I was thinking about inverting the headers to mount the turbos.
(4) I was thinking about running a 4" single exhaust after the turbos. Will this reduce too much back pressure? Any thoughts or concerns?
Now for the other info. My cousin has a modified '87 Ford Ranger. I do not know what he has in his ranger. I have a '96 F-250 with a 460. Both trucks are 4X4. My truck is pretty much stock. I have removed the exhaust from the cat back.
The challenge is this. We are going to meet at a race track for a 5 mile straight run. I know that I am also going to have to have my speed governor removed or set ridiculously high.
Any other thoughts?
__________________
Jeff-Nevada Chapter Leader
Tell me I can't do it or it can't be done I will go out of my way to prove myself right.
People who say it can not be done, should not interrupt those who are doing it. Tom Monson
1996 F-250 4X4 460, 3.55, e40d
1985 D-350 Eventually going to have a Turbo Cummins
1971 F-250 Eventually going to have a 7.3 turbo Powerstroke out of a '99 or newer F-250
  #2 (permalink)
Old 11-05-2008, 03:49 PM
V8Power4x4 V8Power4x4 is offline
V8Power4x4 is starting off with a positive reputation.
This whole plan sounds pretty out of wack just for a race but sure... (Please dont take offence) The only reason I even bothered posting is I can answer one of your questions. Take the exhaust and go big. I come from the DSMing world and one thing I know is you can go as big as you can stand the noise exhaust wise on a turbo.(Or two in this case) All it does is equate to faster spool time and power. Hope this helped.
  #3 (permalink)
Old 11-05-2008, 06:44 PM
jarod17's Avatar
Nevada CL
Thank you for your reply. The race is only making my plans for the truck accelerated. I was planning on a lot of this for my truck but was going to take my time. With my cousins challenge I am speeding up my plans.
Thanks again.
__________________
  #4 (permalink)
Old 11-18-2008, 06:30 PM
jarod17's Avatar
Nevada CL
Nobody else?
__________________
  #5 (permalink)
Old 11-20-2008, 12:46 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
6-8lbs of boost is all I'd run thru a stock motor. Much more and it will blow a head gasket in short order(or the bottom end?).
Headers? Unless you find a set of shorties that you can turn upside down I think a std set for that truck will be a problem. They'll have the pipes into the radiator/hood if you turn them upside down.
Exhaust? I'd run a short dump tube just like most of the car guys. You dont want any restriction after the turbo or will slow down the spool up of the turbo. The turbo is the "backpressure" for the motor.
To get rid of the high speed shut down, you'll need to find a manufacture of a chip for your truck and hope that it has that option. If I recall my '97 F350 was about 95mph? then it shuts down. Not sure if it's just ignition or fuel also? can't just bypass with an aftermarket ignition, as if it shuts down the fuel you'll burn it up with a serious lean out.
A race track with a 5 mile run?? Is this a road course or what? never knew a race track with 5 miles of straightline. Even the Silver State run isn't that long and they run 200 mph. Your truck at much over 100 will be a death trap with the aerodynamics of a large brick, let alone the tires aren't rated for that kind of speed.
Good luck with your project.
__________________
*signature delete option*
  #6 (permalink)
Old 11-20-2008, 02:04 AM
jarod17's Avatar
Nevada CL
Thanks for the info.
The Wendover Open road race is well over 5 miles. My truck shuts down at about 110 MPH. I will have a better estimate of that once I install the Lightning speedo.
Thank you for reminding me about the tires. I will have to get a set of Z rated tires.
For the headers I have found a set of mid length Hooker headers and will be looking into a setup similar to what turbonetics has designed for the new Mustangs. That is still on the drawing board though.
Thank again for your input.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
