Lets see lowered attitude 2wds dents here
#1037
Here you go:
https://www.ford-trucks.com/forums/1...ow-n-slow.html
#1038
I'm not really into lowering but after I replaced the coil springs on mine it just didn't look right. I ended up taking them back off and cutting a coil and half off to get this posture. I don't know how much it lowered it from the factory stance but I like it. The camber is off a little but this will do until I can invest in some drop beams. But it rides and corners just fine though...
Thanks!
Garry
#1041
76 f100
heres mine guys, pulled it out of someones yard, kept it very budget, have $3800 canadian into the truck as a whole, including an engine build, and $900 djm lowering kit.
not happy with the stance, i want to cut a bit off the coils, and i will reorder the rear shackles as i used the lower hole and cut off the upper hole on theose to clear that rear quarter panel support rod.
Id also like to level it a bit and remove a leaf, currently has 5 curved and pinned together thin leafs, and one very thick leaf at the bottom which isnt doing much unloaded. Unsure of which to remove...
#1042
#1043
have a 91 caprice wagon that is my lowrider! That thing is a pain to driv over bumps and into parking lots so didnt want that.
#1044
ya i didnt want to go too low, still want the ability to tow and haul, wanted the shop truck vibe. And for the flup kit did you have to c notch as well? For mine that would have cut into the bed and wasnt about to go there.
#1050
