Lets see lowered attitude 2wds dents here
#916
#917
#920
Yes I did beams in the front and for the back I flipped the front leaf spring hanger and removed the overload leaf. Then I had to add axle shims to get my pinion angle right.
#921
#922
Are the bumper cutouts for brake ducts or lights? I'm planning to do the latter and then a custom air dam with brake ducts in 'em. Post up a thread when ya get to it... I'm sure our fellow FTE'ers would be interested in that low-buck mod.
#923
Nice. Renderings are helpful in staying focused. I hope that the six lug wheels were just part of the artistic license! A product of your work?
And this is where I temporary wired them just to make sure they worked and can be aimed.
#924
Awesome. That looks really good - especially with the square headlights.
It's kind of ironic that your source was a GM product.... I got lil 4-inch rounds from a Pontiac. That's prolly the only good thing that GM is good for... donating parts!
Correct me if I'm wrong but I think that bucket in front of your truck used to contain drywall compound. Lately I've had too much experience with the stuff.
#925
I also really like the rendering of the truck to use as a goal and to stay focused. I really like the Eddie Bauer paint style on the truck. It looks very, very nice, hmmmmm...... I am also going to go for a front airdam effect on mine this year as well and add front brake ducts going to the front brakes. I tow with mine a lot and even though I have the big brakes F250 option it may need more cooling to help everything out a bit. The goal on mine is a resto with more of a roadrace look to it using standard road race effects, side dumps and all.
I dropped mine some by re-arching the rear springs and cutting 1 coil from the front springs, but the nose is still too high. I could heat the coils a bit to drop it more, but I would be severely limiting front travel. Anyone know of a drop I-Beam set that works with an F250? All the ones I have seen are for the F100/F150 chassis?
Thanks,
Eric
Thanks,
Eric
#927
There are a lot of great trucks in here and a lot of great info. I hope Im Not too late in asking or beating a dead horse here, but I have a 78 flare side. I don't want anything too low. Maybe a 2/4. Thinking of shackle / hanger for the rear. For up front im thinking of lowering springs. I Found some from a company called crown suspension out of California. Do y'all think this will be ok? They sell a 2"drop spring for f100's
Thank y'all in advance
#928
#929
#930
I also cut two coils out of mine and I am sitting on factory bumpstops. Are you aswell sitting on the bumps? I thought about buying some thinner one from the local autoparts store.
