Edelbrock performer carb fuel line
If your fuel line is how it came from the factory, you should have a screw-in filter in your 2 barrel carburetor, and a barbed metal fuel line coming from the outlet of the pump. The filter in this setup connects via a short length of hose. The Edelbrock carburetor comes with a barbed fitting, so you just use an inline filter. A short length of hose connects the carburetor fitting to one end of the fuel filter, and another short length of hose connects the other end of the fuel filter to the barbed end of the fuel line. Remember with inline fuel filters, the direction of flow matters and is marked on the filter.
What do you currently have coming out of your pump? The stock pump uses an inverted flare fitting, so you need a metal line with a flare fitting to mate. In stock form, the other end of the line is barbed so as to accept a rubber hose and clamp. Some folks opt for a more expensive braided line, for looks.
Here is how I did mine, though it's on a 460. The line goes directly to the pump with the fittings adapted from the factory. Edelbrock 650cfm with Gates CFC Type AII 2 wire big rig hose + 1200 degree insulation sleeve. I had to get adapter fittings to connect the larger fuel line to the carb, which has a threaded connection. If you want more specifics let me know and I can look up the parts in my records.
Dak
Dak
Ok, I'll get back at ya in a PM when I pull the paperwork. I do recall that it was at a local industrial truck parts place, but can't recall the name/sizes, etc. at the moment (in fact I had to write it all down just to remember to get the right sizes when I got them!...oh this getting old stuff if for the birds!)
Cheers,
Dak
Cheers,
Dak
hail destroyer
09-15-2016 01:18 AM
HillBillyBuddha
26
05-13-2013 01:34 PM
stangfan78
11-12-2008 12:52 AM
IowaTower
07-11-2007 05:28 PM
