hypertech chip-premium gas
Old 11-04-2008, 01:02 PM
wyazel1's Avatar
wyazel1
wyazel1 is offline
I just bought a 95 F250 4x4 460 on Sat and was gonna fill it up today but i was wondering if anyone around here knows if it is necessary to run premium fuel due to the hypertech chip. Its is hypertech part # 458231 if that makes any difference. I have a feeling the previous owner was NOT using premium will I notice any gains? I called hypertech as I typed this post and they said yes they do recommend premium. What have you guys experienced with it? Waste of money, or noticable gain?
Old 11-04-2008, 01:37 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
The chip doesn't change your compression ratio so I would say, no.
Old 11-05-2008, 10:23 AM
46069dord's Avatar
46069dord
46069dord is offline
most chips advance the timming that is probably why they told you that.
Old 11-08-2008, 03:15 PM
Opossum's Avatar
Opossum
Opossum is offline
Once again bear another ignorant answer.
Yes use premium, those chips advance the timing and lean out the mixture. Both of these changes can cause a ping/spark knock with cheap fuel. You may not need premium but start there. Then try half a tank of mid-grade, then a full tank, then half cheap, and so on. While paying attention to the motor and listening for knock.(It sounds like a quiet deisel or marbles in the engine) If it knocks you gotta step up in fuel or remove the hypertech unit.
Old 11-08-2008, 03:21 PM
Bear 45/70's Avatar
Bear 45/70
Anything you say wiseass!
Old 11-08-2008, 03:25 PM
Opossum's Avatar
Opossum
Opossum is offline
Now your getting it.
