I need to remove my door panels to take a look at the window assembly. Doesn't go up and down very well. Do the panels just pop off with a flathead screwdriver?
If they are the same as my 69 F100 there is a chrome and black trim ring around the panel and you should be good. There are screws under the ring. you have to remove the armrest and door handle before you can take the whole panel off.
