Flathead design question
Hi! I'm new to the forum as you can see. Great forum here. There is a question about flathead engines that I have always wondered about. Why have none(to my knowledge) ever been built with valves on both sides of the cylinder bank? A double side valve so to speak. That is, with a straight 4,6,8 there would be two in-block gear driven cams, one on each side, actuating two intake and two exhaust valves per cylinder. With V-type engines 3 cams could be utilized (one intake cam and two exhaust cams). Intuitively it seems as though this could double intake and exhaust flow. Thus improving flathead performance vs a SSV configuration.
Thanks in advance,
Bob
Thanks in advance,
Bob
Chevy 327 V8 weight - 575 lbs
Ford Flathead V8 weight- 569 lbs
First, welcome to FTE!
What you describe sounds close to a "T" head engine.
While your idea is interesting, it would feed such a niche market I'm not sure it would be economically feasible. There have been attempts to cast new "stock" flathead blocks, but it looks like the interest/money just wasn't there to sustain it. A custom multiple cam block would be even more expensive and most likely only attract the salt flat runners and drag strip racers. That's a pretty small group.
I think the bottom line is....well...the bottom line.
Thanks! That would be it. I knew it had to have been thought of. By the look of the drawing I'd say 1920's (no counterbalanced crank). Yeah my design would be an X-head. I was going to design in a raised X in the top of the pistons to give more"squish" on the compression stroke. Two spark plugs per cylinder to even out ignition of the charge. I'll keep dreaming.
Bob
Bob
73GreenF250
08-29-2004 11:02 AM
jwtaylor
36
12-23-2003 09:15 AM
e william
06-17-2003 07:07 AM
