Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters and Ram Air
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-03-2008, 02:09 AM
aggiecowboy1987 aggiecowboy1987 is offline
aggiecowboy1987 is starting off with a positive reputation.
What do i need?
I have a 1996 F350 crew cab 5.8L 351 gas with an air intake that spits into 2 tubes before it enters the engine. I want to delete this and just have one tube that feeds directly into the engine. im trying to get more air into the engine and just want the one tube. i heard there is a kit out there that does this but i dont know what it is called so if anyone could point me in the right direction that would be great. thanks.
Keith
  #2 (permalink)
Old 11-03-2008, 10:57 AM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
That would be the MAF conversion for mustangs. Speed density engines got the two tubes, and MAF systems run on a single. Other wise, you might be able to find a throttle body like the one used on the v10 or supercharged mod motors that will bolt on, then get a boot that will slip over the flange, and fit a 3-3.5" piece of pipe and a cone filter.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #3 (permalink)
Old 11-03-2008, 07:53 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian is gaining momentum as a positive member of FTE. Furian is gaining momentum as a positive member of FTE.
This K&N CAI kit may work for your application.
57-2542 - K&N 57 Series FIPK, Performance Intake Kit
http://www.kandn.com/instructions/57-2542_inst.pdf
__________________
Andrew
2005 F-350 4X4, Regular Cab Long Bed, XL Package, 5.4L 3V Engine, TorqShift®, 4.10 Limited Slip, K&N CAI Kit, SCT Livewire w/ Custom Tunes from 5 Star Tuning
  #4 (permalink)
Old 11-03-2008, 08:59 PM
ReAX's Avatar
2002 Ford F-250
No, the CAI for the dual tube is just a dual inlet filter and bracket. The twin bore throttle body of those years have dual flanges and no sealing surface for a pipe adapter.
__________________
  #5 (permalink)
Old 11-03-2008, 11:55 PM
Furian's Avatar
Did you click on the links? I have the filter / bracket on my 1997 F250 but this kit also works... look at the installation guide (2nd link).
__________________
Andrew
  #6 (permalink)
Old 11-04-2008, 12:16 AM
ReAX's Avatar
2002 Ford F-250
I didn't look at the pdf, it should work then.
__________________
  #7 (permalink)
Old 11-04-2008, 12:44 AM
Furian's Avatar
Quote:
I just wanted to be sure... I've read your many posts and know that you are very knowledgable about Ford trucks.
__________________
Andrew
  #8 (permalink)
Old 11-04-2008, 09:29 AM
so from my reading about speed density to the maf conversion, it seems to me since the computer is getting a more accurate measurement of the airflow in, it might give a boost in fuel economy. I use this truck as a daily driver and haul quite a bit but for the most part id say 60% of the truck is unloaded and im just trying to get more fuel econony. Should this help?
  #9 (permalink)
Old 11-04-2008, 10:18 AM
ReAX's Avatar
2002 Ford F-250
It is a more accurate system, but I am not sure you will see enough gain to offset the $800 price tag. It will help performance and you should gain the ability to tune the ECM.
__________________
  #10 (permalink)
Old 11-04-2008, 10:19 PM
what performance gains should i expect to see? the 5.8L seems small for such a big truck to do any serious towing. ive pulled empty 40 ft goosenecks and i could tell the engine was straining, i couldnt imagine what would happen with a loaded trailer. i probably wouldnt get too far. can anyone tell me what the horsepower and torque specs for this engine in this truck are stock?
  #11 (permalink)
Old 11-04-2008, 10:29 PM
ReAX's Avatar
2002 Ford F-250
It's not just the engine. Final drive ratio and the transmission make a big difference.
K&N shows stock at 211hp http://www.kandn.com/dynocharts/63-1014_dyno.pdf Id figure torque being about 60 higher, so about 270ft/lbs.
__________________
Tags
custom , hook , tow , tusks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
