thanks RP27G8G and Brian for your replies.
The work load for my van is fairly light for a "work vehicle" I haul anywhere from 300# to 400# pounds of tools and supplies daily, sometimes a little less sometimes a little more. Mostly comination in town and highway driving, no towing.
Going with a 4.2L rebuilt, reman, or used will cost more than i care to spend. If i choose to spend near the cost of a 4.2L my thought was could i use a 5.0L for this amount or even less if i do the labor. Clearly the 3.8L is the cheapest and easiest option.
what vehicles make for the best donor of a used 3.8L ?
what vehicle make for the best donor for a used 5.0L and AOD trans ?
what other
parts are required in a 5.0L swap?
thanks again for your help.
