Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-02-2008, 06:42 PM
Taunus Taunus is offline
Taunus is starting off with a positive reputation.
2.8 cologne pistons
hey guys, i want 95mm pistons...we have enuff place?
thanks
  #2 (permalink)
Old 11-25-2008, 10:34 PM
Beanscoot Beanscoot is offline
Beanscoot is starting off with a positive reputation.
Huh?
  #3 (permalink)
Old 02-09-2009, 07:58 AM
kernel-panic's Avatar
kernel-panic kernel-panic is online now
kernel-panic is starting off with a positive reputation.
Even if you bored .060 over, you'd only get it out to 94.5134mm. I personally wouldn't recommend boring out much further than that....
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #4 (permalink)
Old 02-09-2009, 06:38 PM
yes i thinking in 94mm
  #5 (permalink)
Old 02-10-2009, 01:05 AM
My advice is unless you plan on adding a lot of extra cooling capacity and/or risking the engine block cracking, I would not bore the block out more than .030" (to 93.762mm) - at most .040" (to 94.016mm). If you haven't already done it, there is a mod to do to the heads to eliminate the 'hot spot' in the heads where the two exhaust ports 'meet'. It involves using the head gasket as a guide and marking the bottom of the heads for coolant passages in that location - you will want to use a smaller bit than the hole in the gaskets. I don't recall if there is a requirement to also drill the engine block, but it should be fairly obvious. I hope this answers your question
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
