Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2008, 05:42 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
4.2 issues?
Hi Guys,
Ive been cruising the forum here,and trying to make some sense from the 4.2 V-6 issues that are being discussed.
MY 97 has the 4.2,its a LWB,Automatic with 165,000 miles showing.
I have had no major problems with the motor.Ive attempted to change the oil every 3000 miles.Since im not the first owner,I have no idea whats been done previously.The mileage on it when I got it was around 125,000.
I read something about Hydrolock,which is obvious that water is getting in the combustion chambers causing havoc.
Id like some recommendations as to what(if anything) to do.Ive got a well equipped garage,and tools out the wazoo,I have no problems with pretty much whatever is recommended,just want to be sure Ive covered whatever Im capable of doing.
Suggestions greatly appreciated...right now it purrs like a kitten,Im reminded of the old addage "if it aint broke dont fix it"..
  #2 (permalink)
Old 11-04-2008, 12:52 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
The '97 was prone to premature failure of the lower intake manifold gasket and/or the timing chain cover gasket. Ford issued a TSB and revised gaskets and torque procedure. I'd guess your's has been addressed by previous owner.
Just keep a check on the coolant level in the de-gas tank. If it starts to drop, then get it check right away.
As far as routine stuff, what I do:
oil and filter every 5K miles.
Motorcraft Plugs and wires every 70K or so.
Transmission fluid and filter (I just drop the pan, do not do the pump out thing) every 40K miles or so.
For your model year, coolant change every 50K miles or every 2 years or so.
Air filter as needed.
Fuel filter every 30K miles. (they will get pretty nasty)
Standard routine stuff is all these trucks engines need. Anything more, in my experience is a complete waist of time and money.
Approx 330k miles total between my 2000 and my 2005 and I have always kept it simple.
And that has always worked well for me.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #3 (permalink)
Old 11-04-2008, 06:56 PM
n5926g's Avatar
Thanks! This truck is not a daily driver,but its been absolutely amazing concerning the tasks its performed.....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
