code reading? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
code reading?
Old 11-02-2008, 02:19 PM
threefiftyone's Avatar
threefiftyone threefiftyone is offline
threefiftyone is starting off with a positive reputation.
code reading?
Is there a way to get into the OBD-II without a code reader?? I know on some late model vehicles, the techs can navigate the codes within the CPU by just sequencing the correct buttons. Such as sequencing the buttons for cruise control. I've seen it done on my 2007 International 4700. My check engine light/emissions light is on in the Expy. Trying to avoid the dealer
Old 11-02-2008, 08:44 PM
whimsey whimsey is offline
whimsey is starting off with a positive reputation.
No! You have to use some sort of code reader for OBDII. You can purchase these Code Readers at Walmart for around $100 or less. Maybe less somewhere else. "Supposedly" you can get "free" reading at AZ or AAP.
Whimsey
Old 11-03-2008, 06:45 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Was this before or after swapping mufflers?
-- Chuck
Old 11-03-2008, 09:31 AM
After. I ordered a K&N drop in too. When i went to pick it up, the box had been tampered with and it was the wrong filter in the correct box. So they ordered another one. Relevant? Well the old filter was pretty bad, and i had to put that one back in. After that is when the light came on. So, being an emissions light, i assumed putting the bad filter back in was the culprit. I checked all connections and it is still on.
Old 11-03-2008, 11:35 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Possible the MAF sensor got oil on it from the K and N.
Old 11-03-2008, 04:21 PM
nfntruth nfntruth is offline
nfntruth is starting off with a positive reputation.
If you are considering a code reader, might as well by the Scangage, it reads and clears codes as well as all the cool monitoring components.
Old 11-03-2008, 08:42 PM
Quote:
-sorry if i wasn't clear, i never took the K&N out of the wrapper because it was the wrong one. Is the MAF sensor the one plugged into the intake just after the filter? Like i said, the old one (paper) was pretty bad, (oily) and had to put it back in. IF oil did get on it, how do i go about cleaning it? Thanks
Old 11-05-2008, 09:36 PM
well, i had the code read today, and it came up as a emissions code in the intake. The tech (not ford) said that it was probably the MAF sensor. Apparently some of the emission system is covered by a 5 year, 50,000 mile warranty, and some of it is covered by an 8 year 80,000 mile warranty. Other than my extended warranty. Next stop: THE DEALER
Codes in odometer window 02f300 1999 - 2003 7.3L Power Stroke Diesel 12 09-21-2013 10:58 PM
keyfob and lights !!! jdadamsjr 6.7L Power Stroke Diesel 3 06-16-2012 02:42 PM
beeping sequence ddraper Ranger & B-Series 8 09-26-2010 08:37 AM
Cruise Control Diagnostic Question redwood 1997 - 2003 F150 5 10-28-2009 03:51 PM
Function coding Ladder Explorer, Sport Trac, Mountaineer & Aviator 0 11-22-2004 12:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
