Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters and Ram Air
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-02-2008, 01:15 AM
jadmt jadmt is offline
jadmt is starting off with a positive reputation.
460 air intake?
On my 89 f250 w/460 the air intake routes to behind the grill. It has kind of a snout/flap that curves behind the grill and appears to be blocked from getting the full amount of air that would be afforded if the snout/flap were cut off. Anybody cut the end of the intake tube off so it gets a straight shot of air from the grill? It seems that the reason for the curved end is just to keep debris from the air box. Seems like a good filter would keep the debris out and let this monster breath a little.
  #2 (permalink)
Old 11-02-2008, 04:40 AM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
Go ahead and cut that flap off. It a poplular mod for the small block guys who have the air intake that mounts above the radiator support. They get a 460 intake tube that goes behind the grill and chop off the curved section for more airflow. I think it is more effective on the 87-91 trucks as the opening is closer to being directly behind the grill than on the 92-96 trucks. My friend with a 1990 F-250 W/351 just did this.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #3 (permalink)
Old 11-02-2008, 04:34 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
A good filter can do a lot, but if your concerned, you put a prefilter on, make a screen out of pantyhose or use an open cell foam with a lot of surface area.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #4 (permalink)
Old 11-04-2008, 12:54 AM
ClydeSDale's Avatar
ClydeSDale ClydeSDale is offline
ClydeSDale is gaining momentum as a positive member of FTE.
1/4" hardware cloth will keep the grasshoppers, bees, and butterflies off your air cleaner filter
..... at least it works for the whole, intact ones.
__________________
Roger
Clyde S Dale, Camper Pulling Workhorse
1984 F250HD XLT RCLB 4X2 8600 GVW 460 ^Timing C6 Track-loc 4.10's
Trailer Towing/Camper Pkg K&N in/DynoMax out All synth fluids, fully temp gauged
4-core HeatbusteR radiator, dual OE plate type tranny coolers 74,000 original miles (and counting)
ClydeSDale Photo Album
  #5 (permalink)
Old 11-04-2008, 02:07 AM
4scottdcham 4scottdcham is offline
4scottdcham is starting off with a positive reputation.
the verry best thing anny one can do is if at all possable to have eng breath the colest air possoble the cooler the air the better the mph
  #6 (permalink)
Old 11-04-2008, 10:39 PM
Does anybody actually know what that that plastic piece that separates the throttle body and the air box is actually called? It has the plastic pieces that look like air horns. thanks
  #7 (permalink)
Old 11-09-2008, 12:32 PM
I removed the air restrictors via hack saw. I was worried about excessive noise but it sounds fine.I for the life of me do not know how that 460 could breath thru such small openings. They are about an 1 1/4" a piece. Maybe it causes the air to enter the tb's at an accellerated rate do to a ventri effect but it still seems like the 460 would need volume.
  #8 (permalink)
Old 11-10-2008, 12:25 AM
ClydeSDale's Avatar
Quote:
Originally Posted by jadmt View Post
....I do not know how that 460 could breath thru such small openings....
That's the same thought that led me to take off that ridiculous "accordian bellows" air ducting and go for the 4" aluminum tubing
__________________
Roger
  #9 (permalink)
Old 11-10-2008, 12:11 PM
1993 Ford F-250
My friend and I noticed that when we pulled an EFI 460 from a truck I was parting out. Those tubes were ridiculously small. It looked like a 2bbl carb would flow more air than those things.
__________________
  #10 (permalink)
Old 11-19-2008, 03:03 PM
TRNITUP TRNITUP is offline
TRNITUP is starting off with a positive reputation.
ClydeSDale - That's a great setup. But what did you do about the breather hose? Did you cut a hole underneath and feed it up into that aluminum tubing?
  #11 (permalink)
Old 11-19-2008, 07:26 PM
ClydeSDale's Avatar
Quote:
Not sure what you're asking but let me see if I can cover the bases.
In my open air intake project I eliminated the intake "horn" on the aircleaner, the smallish intake in the radiator header and all that accordian tubing in between. The aircleaner housing itself still has all the stock fitings, nipples and connections
Clyde is pretty much a "warm weather" truck so I don't use the manifold heated air intake on start up, that was part of the "horn". If we're discussing the PCV hose, that runs into the air cleaner toward the back using the stock connection. There is nothing between the ~3X10 intake in the header and the aircleaner.
Hopefully I answered your question.
__________________
Roger
  #12 (permalink)
Old 01-13-2009, 02:43 PM
neil 95 e350 neil 95 e350 is offline
neil 95 e350 is starting off with a positive reputation.
i own a 95 E350 EFI van which has an even more restrictive intake than the truck. no intake air horns in the small airbox just before the t-body, but has a small airbox mounted above the radiator that uses the same small airfilter as a 2L pinto. i converted the air intake to a K&N F350 filter and tucked it away in the driver side fenderwell after removing the battery and redoing the entire battery setup. and i fed it fresh air from an inlet in the airdam routed behind the bumper up thru the fenderwell.
to make this short, check into Unique Metal Products (UMP) Home Page for what many feel are the best air filters made. i shoehorned one under the van hood and used 4" alum tubing to do it.
neil
Tags
460 , air , filter , ford , intake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
