Is there an issue with Exped ball joints?
#46
For upper you have the tire off the ground just like when checking lowers. But with uppers you pull and push the top of the tire in and out while looking for play in the 2 halves of the upper ball joint. With the uppers, it really helps to have a second person. One to push/pull the tire and one to watch the ball joint.
Question about the types of play between the two halves of the ball joint. Is it necessarily watching for the stud below to move in the hole, or has that nothing to do? That's the type of thing I've been told to check for, but not sure of that advice. Strange I've never had to diagnose ball joint failure before, but have helped run the rig to replace them on a different vehicle! Never knew what it was like when they were bad because my buddy already had the control arms removed, so didn't get to see this part! I appreciate your help!
#47
A ball joint is nothing more than ball with a stud on it inside of a round socket. When it wears, the gap between the ball and it's socket increases. So you're looking for either up/down or side to side play of the stud that protrudes from the socket. Here is a picture of the inside of a ball joint, if it helps to visualize what I'm saying.
#48
#49
#50
#51
#53
Why do I keep seeing in manuals that the ball joints for my 2000 Exp 4wd 4.6 are an integral part of the lower control arm, and cannot be changed without replacing the arm? And how do I obtain the clearence required to remove the lower arm/balljoint assy. from the knuckle? The torsion bar is siezed and won't slide in either end.Should I remove the cv axle?
#54
#55
I was able to remove the nut and separate the ball joint from the knuckle, but my problem is the control arm either hits on the knuckle or the ball joint hits the drive axle when trying to lift it up and out of the knuckle. The ball joint's threaded shaft won't quite clear the hole in the knuckle. As of now, I have disconnected the stabilizer link, the shock, and the pivot bolts from the lower arm.
#56
#57
#58
#59
