Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 4 Cylinder Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 11-01-2008, 01:15 PM
dannytoro dannytoro is offline
dannytoro is starting off with a positive reputation.
Dumb question on F250
....I have a really nice 1986 F-250 body. Currently there is a vicious 5.0 H.O. police interceptor block from a crown vic in it. That's coming out for a spare engine for our 1992 Mustang GT. Then I have an empty body. Originally I thought about dropping a 300 big six in it. But I just gott a 1984 F100 aluminum flatbed with a 300, and already had an E250 with the 300 too. I love them both. But I'm bored to tears with the idea of another one. Is there a four cylinder engine to try? Or maybe even a diesel to try?...The truck has the AOD tranny in it...Actually the overdrive version that came with the 5.8L v8...
  #2 (permalink)
Old 11-01-2008, 11:12 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
You would have had an E40D or similar, not the lighter AOD.
4 cylinder? Sure, a Honda V-tec, just put some 6.11 gears in there with a 5 speed and a Gear Vendors to split the gears with.
Diesel? Ford installed the IH derived oilburners, you can find one at the scrappy if you want to fool with 1100 lbs of engine plus a different trans.
4 cylinder diesel?
Cummins 4BT & Diesel Conversions Forums
You are not just swapping the engine, but rebuilding the truck for diesel.
fordcummins.com - Increase Horsepower with Ford Cummins Diesel conversion kits
Good luck whatever you try.
  #3 (permalink)
Old 11-02-2008, 11:59 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
My first thought was that the only 4-cylinder that would have enough torque to move that beast would be a Cummins 4BT. But they seem to be a little more rare (and more expensive as well!) than the 6BT. And the '86 F250 had the 6.9 diesel available as a factory option, so that could be done as a bolt-in swap with all parts readily available. Bit of a wiring nightmare though...I've swapped one the other way, converting an '86 F250 4X4 from diesel to gas.
Your current tranny won't work behind any of the above options however. As far as being a bolt-up, it'll only fit the 289/302/5.0, 351W/5.8, 351C or 300-6/4.9 and even if you made an adapter plate, I don't think it would stand up to the torque of a diesel for very long...
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #4 (permalink)
Old 11-04-2008, 06:15 AM
....Wow, the diesel sounds intriguing, but maybe more work then I planned on. I found a guy with a running 460 that doesn't sound too bad, and doesn't seem worn out. I can't hear many problems with the stethoscope anyway. He only wants $300 for it, so I think I'll just go that route. At least then I'll have a great puller in the yard even if I don't drive it much. I'll check out the diesel options in the meantime. Maybe a run over the local Junk yards would be in order. Maybe find the whole drivetrain and electronics. What trucks came with the 4BT and 6BT? Ford used a number of different diesels didn't they?.....
  #5 (permalink)
Old 11-04-2008, 10:26 AM
TigerDan's Avatar
1968 Ford F-250
Ford uses Navistar diesels built by International. The earlier ones were known as IDI, which stands for InDirect Injection but the switch to the Powerstroke came in '94 I believe.
The 6BT is the Cummins engine that Dodge chose for their trucks, though there was also an industrial version used in many different pieces of equipment. The 4BT is exactly the same engine except with two fewer cylinders. It was primarily an industrial engine, though it also found its way into many bread vans and the like, some even running a Ford chassis which meant they came with Ford trannies attached. You'd be very lucky to find a Cummins in the wrecking yard, they just don't seem to show up there. They're in such high demand that they're usually sold from a wrecked truck long before the carcass winds up in the boneyard.
The 460 isn't a bad choice and is also a straight bolt-in swap with the correct engine perches. You'll also need a matching tranny, the 460 shared its bellhousing pattern with the 429, 400 and 351M.
__________________
FTE Moderator
  #6 (permalink)
Old 11-05-2008, 11:16 AM
......Yeap, it was a 351M originally. I didn't care for the 351M in our service vans. High fuel use with not a lot of power from my experience. I think I'll go 460 and not drive it so much. Thanks.......
  #7 (permalink)
Old 11-05-2008, 08:07 PM
TigerDan's Avatar
1968 Ford F-250
No, the 351M was a well-known underpowered, oversmogged dog...not too many folks have much use for them. Too heavy even to be a decent boat anchor...
__________________
FTE Moderator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
