Truck ate my pcm and starter - Ford Truck Enthusiasts Forums
Old 10-31-2008, 12:43 PM
cornutsoffroad cornutsoffroad is offline
cornutsoffroad is starting off with a positive reputation.
Ok i went home checked all the wires and pushed all the connectors in tight the p1283 came up and two for the pcm came up < p0603-continuous powertrain control module keep alive memory (KAM) Error> and < p0605-powertrain control module read only memory (ROM) Error> do either of these codes mean my pcm is toast or a bad wire somewhere? O and i finished off the second new starter last night after about 5 cranks.
Old 10-31-2008, 01:54 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
p0603 is common when the batteries are disconnected. no worry.
Are they new starters or re-mans. Remans can be bad right out of the box.
DTC 0605 exists only when there has been an internal failure of the PCM
Clear the code and rescan to be sure.
Old 10-31-2008, 03:02 PM
Yea I bought my last reman from autozone I found a brand new starter online I cleared the code o6o5 from the memory but it comes up when I scan koeo on the scan tool
Old 10-31-2008, 03:23 PM
The onboard computer, or Powertrain Control Module (PCM),is the brains of the engine control system, so when the brain is not functioning correctly neither is the engine or anything else that the microprocessor controls - which may include the charging system, transmission, various emission controls and communications with other onboard control modules. Once a diagnosis has been made (and we emphasize the word diagnosis), then and only then should the PCM be replaced.
Onboard Diagnostic (OBD II) diagnostic trouble codes that typically indicate a fault with the powertrain control module include:
P0600....Serial Communication Link
P0601....Internal Control Module Memory Check Sum Error
P0602....Control Module Programming Error
P0603....Internal Control Module Keep Alive Memory (KAM) Error
P0604....Internal Control Module Random Access Memory (RAM) Error
P0605....Internal Control Module Read Only Memory (ROM) Error
P0606....ECM/PCM Processor
P0607....Control Module Performance
P0608....Control Module VSS Output 'A'
P0609....Control Module VSS Output 'B'
P0610....Control Module Vehicle Options Error
If you see any of these codes when diagnosing the vehicle with a code reader or scan tool, it may mean the PCM has failed and must be replaced. Additional diagnostic tests will usually be necessary to confirm the problem is really the powertrain control module and NOT something else. Refer to the OEM diagnostic charts for what these tests are. Usually it involves checking certain inputs to the PCM to see if it outputs the correct response. No response or an incorrect response usually means the PCM is defective and needs to be replaced.
Old 10-31-2008, 03:25 PM
does this mean i have to replace my pcm? does anyone know where i can take it to get tested?
Old 10-31-2008, 04:08 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Excessive cranking can cause the P0605 per the link below ,, about halfway down.
Oregon Fuel Injection, your diesel fuel injection specialist, rebuilt turbochargers, injectors, pumps and diesel performance products.
Some other good information in there too.
Old 10-31-2008, 05:31 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
From the manual...
AG1 DIAGNOSTIC TROUBLE CODE (DTC) P0605: PCM ROM FAILURE
  • DTC P0605 exists only when there has been an internal failure of the powertrain control module (PCM).
  • Rerun Scan Tool Diagnostic Test.
Is DTC P0605 retrieved?
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPLACE PCM. </TD><TD width="50%">System OK. RERUN Scan Tool Diagnostic Test to see if there are any other stored DTCs. </TD></TR></TBODY></TABLE>
Old 10-31-2008, 05:34 PM
Great site ....
Old 10-31-2008, 06:44 PM
Hussler's Avatar
Quote:
Originally Posted by Action4478 View Post
Great site ....
x2 - yep on top of page under "Service Tips" select 'Ford Diesel' and it is one of the most comprehensive detailed diagnostic (all in one place) tool I've seen and addresses most problems seen here.
Old 10-31-2008, 08:15 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
Very Good site!! thanks Hussler, reps would be sent but I need to spread the wealth.
Old 11-01-2008, 01:34 PM
Quote:
Got it for Ya....
2012 F350 6.7L Diesel No Crank Kalmans 1999 to 2016 Super Duty 1 03-14-2017 12:03 PM
2004 Ford E250 4.6 V8 trouble codes rustyandleaking 1968-2013 Full Size Vans 3 12-30-2016 01:16 PM
Rough idle help needed wyoclint 1999 - 2003 7.3L Power Stroke Diesel 11 12-15-2016 05:02 PM
P1444 Code Norsegod127 Ranger & B-Series 1 05-16-2015 05:44 PM
Early 99 PSD "No Start" Catchup 1999 - 2003 7.3L Power Stroke Diesel 44 01-16-2009 05:02 PM
Tags
73, alive, ecm, error, f350, kam, mean, memory, p0601, p0603, p0604, p0606, pcm, powerstroke, processor, reman
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
