2005 f250 max tire size?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-31-2008, 10:07 AM
cornfiled stroker cornfiled stroker is offline
cornfiled stroker is starting off with a positive reputation.
What size of tires can I put on without rubbing on a stock 2005 f250 6.0 4x4?? Thinking of going with BFG All Terrains. Will probably do a leveling kit later on.
Thanks
Old 10-31-2008, 09:13 PM
onuredneck707's Avatar
onuredneck707 onuredneck707 is offline
onuredneck707 is starting off with a positive reputation.
I have BFG AT's on mine. They are 285/70R17's. I would think you could fit 35's but I have been wondering the same thing myself.
Old 10-31-2008, 09:47 PM
Heavy_Metal Heavy_Metal is offline
Heavy_Metal is gaining momentum as a positive member of FTE.
I wouldn't go over 285s or it starts to look funny.
Old 10-31-2008, 10:08 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.DCSpecial has a great reputation on FTE.
I run 325/60R18s on 18x8.5" Welds under my stock height 07.
Old 10-31-2008, 10:22 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
Quote:
DC is there any height difference between a leaf sprung 1999-2004 vs the newer coil sprung 4x4's? (F-250/350)
just curious
Old 10-31-2008, 10:31 PM
DCSpecial's Avatar
My 07 with 6000lb coil springs did sit slightly higher than than my 99-04s with x-code front springs.
Now with 7000lb coils in it, it's definitely taller.
joesf250's Avatar
joesf250 joesf250 is offline
joesf250 is starting off with a positive reputation.
tires
hey i have 305/70/17s they are summit mudd dawgs and i hate them but there about 34ish i think on the inch side of things and no lift on the truck according to tire calculator they are 33.8
Old 11-01-2008, 12:28 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
I have a 2005 F250 and have 295/70/17 (34" tires). I measured mine and my friend's trucks (2005 F250/2005 F350). Mine has a gas engine, his a diesel. His sat one inch lower than mine in the front and one inch higher in the rear. The trucks were optioned the same, so it's my contention that the diesel sits one inch lower in the front, so you may be real close with 35" tires.
Old 11-01-2008, 02:07 PM
joesf250's Avatar
cornfiled stroker i have put a new pickture on here so you can see the clearance in the tire and body on a stock 2005 f250 6.0l 4x4 with 305/70/17witch is a 34"
what wheel/tire combo will fit? Bite N Hold Excursion - King of SUVs 10 02-11-2015 07:48 PM
Spare Wheel size for 2005 X smokedog Excursion - King of SUVs 3 08-02-2014 08:34 PM
2005 f150 fx4 gear ratios f-1filthy 2004 - 2008 F150 5 11-16-2012 09:17 PM
2008 20" wheels on a 2005 F-250 buckweet1980 1999 to 2016 Super Duty 12 09-06-2007 12:00 AM
biggest tire size for 2005 f 250 gdb1960 1999 to 2016 Super Duty 2 02-07-2005 01:22 AM
Tags
04, 1992, 2000, 2005, 2008, 2wd, 4x4, f250, ford, max, size, sizes, tire, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
