I just drained the oil on my 2004 F250 and I can't get my hood to open to change the filter and refill
When I pull the lever inside the truck it feels as if it engages fine but the hood does not open. I dont have a helper here to pull the lever while I push on the hood and I need to be some place in 1.5 hours!!
Got it thanks - I did not have a helper so I had to wedge something between the lever and the kick panel to keep the lever pulled while I pulled on the hood
Yes, soak it down with WD40 or your favorite pressurized penetrating oil. Once you get it clean (it may require some brushing) then coat it with a light application of white lithium grease.
