6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Hose leaking replacement question
Old 01-19-2019, 12:51 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
SUPERDUTY_08 is offline
I just had my radiator replaced the other day, and now it seems a hose is leaking from what i think is the transmission cooler. My question is, can just the rubber hose part be replaced or is it attached to the solid line?
Old 01-19-2019, 04:11 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is online now
Slide the clamp up and give it a go. Looks like it was just slid on the nipple and never licked it.
Pair of pliers should do it. Rotate the line by hand once seated. Should be good. If it still leaks there, trim off the end of the hose so it loses it's memory and then reseal.
Top off if necessary.
Denny
Old 01-19-2019, 08:53 PM
SUPERDUTY_08
Denny
ill give it a try. Worse case, i just replace the entire tubing. Its only $40. I figure that rubber is 12 years old, so it may be getting dry.
Old 01-19-2019, 09:29 PM
DieselDenny
Been married thirty two years, I just move the clamp from time to time. It'll work.
Denny
Old 01-19-2019, 10:13 PM
SUPERDUTY_08
Denny
what? Lol. That went south fast.
Old 01-20-2019, 10:29 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Denny, you always put in a little extra.
Thanks
Old 01-20-2019, 12:40 PM
SUPERDUTY_08
Denny
it looks like the hose is cut a little to low. So ill just replace the whole thing. The rubber hose isn't long enough to trim. I could cut the existing hose and add a short section with a barbed fitting. But that seems like more work than just spending $40 on the new part.
Old 01-21-2019, 01:02 PM
SUPERDUTY_08
Well i brought the truck do the dealer to get looked at. Ended up having the complete tube assembly from the transmission cooler back replaced . lets hope this is the last of issues for a while
rpatrick
1997-2006 Expedition & Navigator
03-14-2018 09:10 AM
vjsimone
All Other Items for Sale
12-17-2017 10:29 PM
r2millers
01-12-2012 09:54 PM
TMattson
1997 - 2003 F150
02-14-2010 09:27 PM
rcn
07-27-2009 06:26 PM
Quick Reply: Hose leaking replacement question
