JP8 (jet fuel) in place of diesel - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-11-2008, 07:31 AM
NickBurk NickBurk is offline
NickBurk is starting off with a positive reputation.
Quote:
Originally Posted by cmpd1781 View Post
Because it sounds cool.....
Not only is it cool...but it's jet fuel...comon...who wouldn't want to put jet fuel in their personal vehicle. The post I'm at has an endess supply it seems... hahaha
Old 12-11-2008, 07:59 AM
cmpd1781's Avatar
cmpd1781 cmpd1781 is offline
cmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputationcmpd1781 has a superb reputation
Quote:
I suppose 6.4L owners and the manufacturer would know much more than me....But I would be hesitant to put anything in these new engines with their particulate/emissions systems that WASN'T ULSD (15ppm max)......
What would happen with the warranty if the engine or the emissions system went teats-up, and they found jet fuel in your tank and lines? Is it worth it to take the risk?
Now my 7.3L on the other hand.......Hmmmmmm........
But yes. Free is good.
Old 12-12-2008, 04:54 AM
glsurratt's Avatar
glsurratt glsurratt is offline
glsurratt is gaining momentum as a positive member of FTE.glsurratt is gaining momentum as a positive member of FTE.
Ohhh - and no road taxes!
Old 01-12-2009, 09:44 PM
bigdogjohn1 bigdogjohn1 is offline
bigdogjohn1 is starting off with a positive reputation.
Jet fuel is Kerosene
Old 09-12-2012, 09:40 PM
dainguy82 dainguy82 is offline
dainguy82 is starting off with a positive reputation.
2008 6.4L ford using JP8
I have the DPF deleted on my truck. Would I be able to use JP-8 in my truck? The EGR is still on the engine but I don't know if it would do anything since the DPF is deleted cause I want to use JP8 but I don't want to mess up my engine or injectors or fuel pump or any of that stuff. I've read a few reviews and some people say its safe and others say it will mess your engine up over time. Can some give me a clear concise answer please lol??
Old 09-13-2012, 06:43 AM
R-T0r21on R-T0r21on is offline
R-T0r21on is starting off with a positive reputation.
The ARMY uses JP-8 in their diesel engines. when you convert from diesel fuel to JP-8, it will clean out the tank, lines, etc., so keep extra fuel filters handy for a little while. The fuel should be ok to use since you're deleted. BTW - I believe Jet fuel is JP-4.
Old 09-13-2012, 06:42 PM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
You guys should think twice before putting anything in the tank other than ULSD.
I'm not saying it won't work, but fuel system repairs on 2008 and newer diesels are pricey (10,000$ +)
The biggest problem I see is the lube... HPFP's fail from a lack of lube.
Old 06-25-2014, 02:32 PM
WoundedVet's Avatar
WoundedVet WoundedVet is offline
WoundedVet is starting off with a positive reputation.
7.3I chews through JP-8
Old 07-08-2014, 02:33 PM
MitchPeters MitchPeters is offline
MitchPeters is gaining momentum as a positive member of FTE.
The free fuel is most likely what is pulled out of each tank for a sample and put into a waste tank. Not sure if it is a daily sampling or weekly. After the waste tank is full a waste hauler is called to empty the tank.
Old 07-12-2014, 09:07 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
YES! And JP-8 has far less lubricity compared to regular DF-2
I would not put it in ANY common rail engine without a bunch of oil added......and oil will add it's own problems.
It might be "better" to just run regular diesel.
Old 07-14-2014, 11:04 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
Jp8 is even hard on older injection pumps also. Diesel is cheap compared to parts.
Sent from my leash using IB AutoGroup
6.8 V10 jp petracco Excursion - King of SUVs 11 01-04-2015 04:40 PM
JP-8 Jet Fuel LKCKR 6.0L Power Stroke Diesel 53 06-21-2014 09:24 PM
safe wvo blend in stock system, 02 7.3 Whitson Metalworks Bio-diesel, Propane & Alternative Diesel Engine Fuels 12 10-03-2013 07:33 AM
7.3L Fuel Alt w/out adding tanks or parts?? babyheals Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 12-29-2012 06:46 PM
fuel help please blksiryder Bio-diesel, Propane & Alternative Diesel Engine Fuels 12 07-13-2007 06:21 AM
Tags
08, 64l, 73l, buffalo, comparison, df2, diesel, ford, fuel, jp, jp4, jp8, lubricity, run, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
