You're asking a lot of a clutch type, stock limited slip. It is meant for low traction situations, not pitching it sideways on dry pavement.
A locked rear axle via a spool will push you off the road under the right conditions, and over time will break the axles or at the very least wear your
tires oddly and provide clunk and chirp action for your driving pleasure.
More aggressive limited slip (more clutch plates), lockers like the Detroit Locker, or selective lockers like the ARB are available.
