I Give Up: Can't Find Fuel Leak on Right Side of Engine
I have a fuel leak. I have crawled all over this thing and can't find it. The leak is on the right side of the engine. It drips a lot after shut down and drips lightly when running.
The drip is somewhere on the right side of the engine it seems. I can see the drip when I shine a flash light in the space behind the box immediately behind the right battery.
It is dripping from under the header (i think) and is dripping down on the starter.
When I look at the bottom of the engine, the starter is wet with fuel and fuel is also dripping lightly out of a drain hole on the thin metal plate that covers the gap between the transmission and the engine.
I found a small puddle of fuel on the top of the engine just under the fuel filter box (not sure what the right name is) I found two loose fittings there and that seems to have stopped the leak there.
I am very diligent about maintenance and these leaks have just appeared yesterday.
Please tell where to find this leak if you have any ideas.
Thank you.
Thank you.
Navdriver
1997-2006 Expedition & Navigator
13
04-19-2007 02:20 PM
