NEW MEMBER Introduction Thread (NO TECH QUESTIONS)
#1066
lollarj
I am a newbie here so......forgive if I fumble a little here. I am a pround owner of a 2003 National Seabreeze Class A motor home. It has a Triton V10 under the front hood. I am looking for a service manual for the V10. Can any body out there direct me to where such a manual being hiding.
I am trying to locate the low pressure side of AC to recharge it. Any thoughts out there.
#1068
Hello from Arizona
Just found the board so I thought I'd sign up.
My Ford is a '99 F250 w/ a 7.3 PS Turbo Diesel. I just rolled over 309,000 miles and she is still pulling strong, and still the best dang truck I've ever owned.
No major mods; Superchip, Firestone bags, and that's it. I've always wanted an exhaust for it, but I just haven't gotten around to it.
Anyway, take it easy everyone, I'll see you around the forum.
#1069
#1070
Hello from Ohio
I've been poking around here for a while, just never registered. I've had 2 superduties before, both with V10's. Really loved the V10. I rolled my last one in February (damned ohio winters), and I'm going to pick up another today-a '99 4x4 supercab with a 7.3 Powerstroke. It will be my first diesel, so I'll have a lot to learn. Plan on trying my hand at biodiesel this summer.
Chris
Chris
#1073
Which is Better?
As you can see, I'm new on here. But thats beside the point.
I was wondering how many of you on here think that the 5.4 330 v-8 is better than the old 5.8 351(windsor, cleveland, modified) series engine, and vice versa. I like both body styles the engines are found on, and personally like the 5.4 better. But I was just curious.
Thanks
Thanks
#1074
#1075
Hi hoffbrew, I am new here too so watch me stumble. I had that problem once. I over oiled the aftermarket air filter, it softened the connector hose and blew off. So i picked up a new connector hose and cleaned the oil residue off the innercooler pipe. That solved my problem. I was also told not to completely crush the spring on the hose clamp when I tightened them. Don't know if I helped you any. Good luck and good times. P.S I went back to the factory air filter.
#1076
#1080
Hey everybody. I just bought my first NBS Ford after owning 15-20 OBS Fords. It's a 99 F250 SD 4x4 Lariat V10 and it turned 45k original miles the other day. I'm sure I'll have lots of questions. Here's a link to pictures of some of my old Ford trucks: Fords - a set on Flickr
