how are these fuel pressure readings ?
Now that I can watch it, been able to watch my fuel pressure. Mind you this is a stock fuel set up, still have the bowl / filter, stock pump with no extra pump, and added a rail filter as part of my harpoon / hutch mods.
-While cruising about 55-65 mph, reads right at 60-62 psi
-If running about 30-40 and do a hard accel (with DP tuner in 80 econo) pressure drops to just below 60 psi
-From a stop, in 80 econo, on a HARD acceleration it drops to just above 50psi.
Seems like I lose a lot of pressure when I'm really demanding fuel, right ???
Just an update:
my truck runs on WVO and I just went through my first filter, as it was getting too dirty to run my pressure was dropping, check you filter, this may be the problem.
After replacing the filter I had to let my truck idle for about 20min before all the air was out of the system, with air in the system the pressure would not stay constant at all, and would fall below 50 if I gave any throttle at all.
That's what I did too. The Walbro outflows the stock pump, and only costs about $125. If you have already done the pre-pump mods, then this pump is a straight up bolt on. I can't get it to drop any pressure even on my highest setting, and I'm running close to 70 psi of pressure.
