2004 3.0 timing adjustment - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-28-2008, 04:20 PM
jm ray jm ray is offline
jm ray is starting off with a positive reputation.
can anyone tell me if a 02 ranger 3.0 ,has a spout connector. or explain how to adjust the timing. i can not find a connector like on the older trucks.just have replaced head gaskets. it runs but i do not know how to set it correctly. thanks
Old 10-28-2008, 08:27 PM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
An 02 would have a distributorless ignition, so you probably won't find a spout connector, and won't be able to set the ignition timing.
Old 10-29-2008, 12:31 AM
MazdaRangerGuyInSTL MazdaRangerGuyInSTL is offline
MazdaRangerGuyInSTL is starting off with a positive reputation.
I think you're confusing the camshaft synchronizer with the distributor.
There is no distributor. The Synchronizer installs where the distributor (on old models) used to, and is used by the computer to determine camshaft position. The computer, in turn, uses this as PART of its calculations for ignition timing and fuel injector timing.
With that being said, positioning this properly is extremely critical. There are two methods... you can use a static timing tool (look for camshaft synchronizer alignment tools) while installing it with the engine at Top Dead Center.
The other method involves using a multi-channel scope and overlaying the camshaft waveform pattern over the crankshaft waveform pattern, and adjusting it with the engine idling until they intersect at a specific point. There is a 17-page TSB from Ford explaining exactly how to do this, but I have a feeling you'll be following the first method.
Old 10-29-2008, 04:28 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Good advice so far. But I'm going to nit-pick just a little:
1. On some older DIS systems there is still a SPOUT connector. However, even on these systems you cannot adjust the timing. It is set at 10* BTDC from the factory and is controlled dynamically by the PCM.
2. Newer EDIS systems (as opposed to DIS) do not use the camshaft position sensor signal for spark timing; instead, the CMP signal is only used for fuel injection timing.
See: Ford DIS & EDIS Ignition Systems
P.S. Here's another way to "set" the CMP sensor signal: http://www.ford-trucks.com/forums/sh...3&postcount=33
Urgent, please help! 86ford302help Ranger & B-Series 12 06-01-2015 12:28 AM
Connector c126 wtroger Ranger & B-Series 6 03-17-2015 09:54 AM
ignition timing spout connector Nally427 1987 - 1996 F150 & Larger F-Series Trucks 6 08-06-2012 01:50 PM
91 F700 timing on the 7.0L? rotun Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 04-14-2010 10:05 PM
timing adjustment 95' F150/302. HELP! Duderoy 1987 - 1996 F150 & Larger F-Series Trucks 7 02-19-2003 09:38 PM
Tags
04, 2004, 30, 30l, adjustment, camshaft, ford, injection, position, ranger, sensor, setting, timeing, timing, vulcan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
