Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Ohio Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
  #1 (permalink)
Old 10-28-2008, 08:10 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
Garage is empty, add now
bigwin56f100 has a great reputation on FTE.bigwin56f100 has a great reputation on FTE.bigwin56f100 has a great reputation on FTE.bigwin56f100 has a great reputation on FTE.
Heat source for your shop or garage, what do you use?
I was wondering what everyone else uses, wood, gas, oil, waste oil, electric, or kero or other. Tell us about what you use, here is what I have planned:I've had a new shop built(30x60) and its too big to heat the entire thing. We have decided to build a room inside (20x20) and heat this are only. I have a gas line installed for a wall mount radiant heater. Room will be insulated and drywall.
__________________
"Some trucks must die for other trucks to live"......... Kevin
  #2 (permalink)
Old 10-28-2008, 07:50 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain has a good reputation on FTE.Freightrain has a good reputation on FTE.
I have one radiant wall mount in my garage. I leave it at minimal setting usually to keep thing from freezing. Bump it up when I work out there. My garage is 24x48, with one 12x24 area closed off separately. It's well insulated, but I'd like to add better heating for when I'm working as the radiant doesn't heat the area very well(too large).
This is the way I bought the place, and I haven't changed anything. I had a spare house furnace I was going to do forced air, but just wasn't room for it(too much junk).
__________________
*signature delete option*
  #3 (permalink)
Old 10-31-2008, 08:16 AM
garypettengill's Avatar
garypettengill garypettengill is offline
garypettengill is gaining momentum as a positive member of FTE.
I do not have a separate shop, wish I did. I am lucky enough to have a 3 car garage. Wife got her kitchen, I got my garage. It is well insulated and the combination I use is a propane fueled torpedo heater to take the chill off then my kerosene radiant heater to keep things comfortable. Works well unless it's really, really cold out. Then I just stay in the house.
  #4 (permalink)
Old 10-31-2008, 12:21 PM
Shiftoholic
My 12x24 area is actually the parking spot for my '69 F100. No extra room except for hanging parts on the wall. My property was a rental house, the garage had one spot for renter and the rest was for the owners business. I opened a doorway into the separate garage area to be able to get to it without going outside, but it's too small for my galaxies(since I have stuff stored in there too), so the pickup fits perfect. No actual heat to it, whatever radiates from main garage. The building is fully insulated, so it was pretty air tight when I first bought it.
I agree, when it gets frigid..........no quantity of heat makes me want to go out and work.
__________________
  #5 (permalink)
Old 10-31-2008, 03:21 PM
F250FarmBoy's Avatar
F250FarmBoy F250FarmBoy is offline
F250FarmBoy is starting off with a positive reputation.
This is the first year I'm using free natural gas from a well on my property (200,000 free cubic feet/year and since last april we've only used 14,000). Depending on how much we use during winter, we'll build a small shop and heat it with the free gas.
__________________
1985 F-350 6.9L 2x4
Flatbed, DRW, 4.10's, ZF-5 swap, buckets, push button GP's, 103k miles
1989 F-350 7.3L 4x4
Kingpin D.60, Srw, 4.10 l/s, push button GP's, ex-tree service truck, dumped utility bed for the bed off an '89 . Soon to get paint with the idea of yellow and black "boss 302" graphics....but it won't say "boss 302"
  #6 (permalink)
Old 10-31-2008, 11:19 PM
I've been of free gas now for 15 years, problem here is the well was drilled in 1980, I bought in 1993 and now the well is going dry. I only have enough gas to run the hot water heater, gas stove, gas dryer, outside gas grill for about 7 months out of the year. once my gas hog furnace kicks on its all gone! I usually get enough for free weekends in the winter and burn wood to heat as well. Its still a savings but not like it used to be, the old shop was always 65 -70 it was great!
Kevin Bigwin
__________________
  #7 (permalink)
Old 11-01-2008, 07:24 AM
F2504x4's Avatar
F2504x4 F2504x4 is offline
2002 Ford F-250
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
thermos..........
  #8 (permalink)
Old 11-02-2008, 07:22 PM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a good reputation on FTE.WALFORD'S 56 has a good reputation on FTE.
My hot-rod barn is 24 x 34 and has no heat. Maybe in a few yrs if I need it. I use propane heat if I need to do anything.....but I have a ranch in Florida with a huge shop and it is usuallly at least 70 degrees in January when I go for the winter. No heat in there either...haha!!! I have 3 trucks down south and 8 trucks up north. After this week --it will start gettin cold......might go with overhead tube style heat up at this barn ...I had this in my machine shop along with infrareds and I liked it alot.....Bill
  #9 (permalink)
Old 11-03-2008, 08:52 AM
Shiftoholic
I thought of getting one tube heater put in so the heat is put out over the entire garage instead of one side of the car(opposite of my work area), so my welder and cutting torches are nice and toasty all winter while I shiver over by the workbench!
__________________
  #10 (permalink)
Old 11-09-2008, 11:51 AM
Yes--the tube heating is real nice.....and can even paint with it.....had a set of tubes in my new paint booth (binks) back in 1994 and it was awesome. AH....WISH I still had it....Bill
  #11 (permalink)
Old 11-12-2008, 08:27 PM
BlackBetty05's Avatar
BlackBetty05 BlackBetty05 is offline
BlackBetty05 is starting off with a positive reputation.
I'm currently using one of those patio heaters. It's o.k. but it's not going to roast you out of there that's for sure (24 x 24 detached garage). Now I do have a 3 burner 40,000 btu radiant heater brand new in the box but....no gas line. I don't imagine it would be to difficult to trench a line out there
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
