Starter Relay Location???? 2003 F450 6.0 - Ford Truck Enthusiasts Forums
Old 10-27-2008, 08:58 PM
RDC F250 7.3 RDC F250 7.3 is offline
RDC F250 7.3 is starting off with a positive reputation.
I can jump the starter under the truck, and start it. Sometimesthe key works after the truck has been running a few mins. But if I let it sit for an hour or so, I have to go under the truck and jump it at the starter.
Could the relay be doing this??
New Starter, New Batts!
Help
Old 10-27-2008, 09:51 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
EOD Guy is starting off with a positive reputation.
Did you check the 30 amp fuse? It's F2-113, Bottom row left hand side 2nd from the end. They are the slow blow type.... try switching it out withanother one and see if that fixes it, there is a starter relay, It's in the central junction box, up under the brake pedal area on the fire wall.
Old 10-27-2008, 09:55 PM
EOD Guy's Avatar
Just noticed you were asking about a 450 I not sure if it is the same as a 250
Old 10-27-2008, 09:56 PM
I can't see that I would have a blown fuse, It starts with the key sometimes. But I will check the starter Relay!
Central Junction Box??? Under the Hood??
Thanks EOD
Old 10-27-2008, 09:57 PM
EOD Guy's Avatar
I Just noticed you were asking about a 450, I'm not sure it's the same as a 250
Old 10-27-2008, 09:59 PM
EOD Guy's Avatar
I'm not saying it's a blown fuse but a damaged one, just barely making contact some of the time. I had a simular incident with a fuel pump fuse on a gasser, I replaced the fuel pump only to find out it wasn't bad but that 90 cent fuse was....... easy check
Old 10-27-2008, 10:04 PM
EOD Guy's Avatar
According to the wire charts the central junction box on a 250 is located in the interior, on the firewll near the center portion on the truck
Old 10-27-2008, 10:12 PM
EOD Guy's Avatar
Is this for a standard or auto? Another area you might check is the clutch/netural switch ...... if it's auto try moving the gearshift lever as you try and start it (guessing here)
Old 10-27-2008, 10:19 PM
Auto, Relay is still my pick!
Old 10-27-2008, 10:31 PM
EOD Guy's Avatar
Cool.... Fuse, relay, netural sw, chaffing wires/loose connection...order of ease
Old 10-27-2008, 10:36 PM
Fuse is good. Checked the relay, its clicking when I turn the key.
Let me step back a sec and tell you the the starter was replaced 1 week ago.
This might be in the starter or loose connection, but this will have to wait till the AM.
Thanks for your help EOD
Starter Relay & Starter issues - 12v Mab1957 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 10-21-2015 02:25 PM
Starter circuit issues wetbiker 6.0L Power Stroke Diesel 0 08-15-2015 11:45 PM
Truck will not start on occasion psvienneau 1999 to 2016 Super Duty 1 02-07-2014 09:39 PM
98 F150 Won't start triplehellcat 1997 - 2003 F150 9 01-04-2014 07:13 AM
EEC Relay Help Swatter 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-31-2009 10:44 PM
Tags
1998, 1999, 2003, 2005, 60, diesel, f250, f450, ford, liter, location, relay, solenoid, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
