223 from car vs. 223 from truck
Don't drop the block on your foot! (Sorry, I couldn't resist)
1960/63 Galaxie & 1960/64 F100 223's are the same, right down to the exhaust manifold, carb, waterpump, generator, etc.
The same 3 speed manual all syncromesh transmission was used in both cars/trucks.
The same A/T was used in both cars/trucks.
The only thing different is the motor mounts, as the cars use different ones.
btw: The last year for the 223 in Galaxies was 1963, in trucks = 1964.
I ran into a problem in the water pump area with my passenger 223. My truck water pump bolted up OK, but there was one small hole in the block, on the driver's side, that I had plug. In the auto parts store catalogs, the passenger 223 water pump looks much different than the truck version.
Probably best to stick with the passenger car water pump if you can still route hoses to the truck's radiator inlet and outlet without kinks. I didn't have a passenger car pump handy, so I just tapped the hole lightly and used a pipe plug with plenty of sealer.
The passenger 223 will probably also have the "silent lash" or "zero lash" rocker arms, which came out late in the 223's lifetime. They take a different adjustment procedure than you're used to, but they work just fine.
Thanks again. Question regarding "silent" or "zero lash": does that mean the passenger car 223 had hydraulic lifters vs. the truck's solid lifters?
A spring-loaded plunger in the body of the rocker arm pushes on a cam mounted to the tip of rocker. As the cam at the tip rotates outwards, it takes up the valve clearance.
Check out eBayMotors items 110255259057 and 120324099589 for a picture.
Nobby
04-11-2016 06:29 AM
crystalhand
11-24-2015 08:37 AM
Archaeon
11-16-2015 08:31 PM
itsmywifestruck
06-24-2008 10:09 PM
