Need to replace fuel filter retaining clips - Ford Truck Enthusiasts Forums
Old 10-27-2008, 04:52 PM
Mike-G Mike-G is offline
Mike-G is starting off with a positive reputation.
Hey all. Been a while for me here, but I'm back. The last time I changed the fuel filter on my 99 F150 5.4L, I learned the right way to do it ... because I did it the wrong way. I didn't know I needed a special tool and mangled the spring steel clips inside the ends of the fuel line. I bent them back best I could and put it together. It's been fine for years but I want to change the filter again now and would like to put new spring steel clip retainers in there. Any idea where I can find them? Dealers have told me that I can't order just the clips and the local parts stores are clueless.
Thanks,
Mike Gregory
Old 10-27-2008, 05:12 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Quote:
If you're talking about the circular ones with 5 or 6 fingers pointing up on them, the base number is 9B307. They are sold seperately but I don't think they can be looked up by application. Count the number of fingers (prongs) on yours and post it here, Ed or number dummy or somebody should be able to give you the correct Ford part number.
Old 10-27-2008, 05:17 PM
FTE/PARTS-GUY FTE/PARTS-GUY is offline
Former Vendor
FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.FTE/PARTS-GUY has a great reputation on FTE.
E9UZ9B307A 6 TABS 13MM O.D
E9UZZ9B307B 5 TAB 10.5MM O.D
Ed
Old 10-27-2008, 05:20 PM
fuel filter spring steel retaining clips
Ron,
I looked at the local parts store and they had some Dorman fuel clips but none of them looked anything like I remember mine looking. The ones in the store had nearly straight fingers and were not a continuous ring. From what I remember on mine (going back a couple of years), mine were a continous ring with the barbs kind of bending back like a claw. I found a plastic one from Dorman that fits 1/4" filters. This went on the filter I was buying but I have no clue as to if it will go in and or stay in the fuel line. Still looking for help.
Thanks,
Mike Gregory
Old 10-27-2008, 06:13 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Ed
Not to nitpick, only in the interest of accuracy, but I think there's an extra "Z" in the 2nd part number. If you're dealing with a Ford dealership who's Parts Dept can't come up with these clips the numbers you give them had better be right!
Here are pics with the clips installed.
Old 10-27-2008, 06:22 PM
Former Vendor
Quote:
I tried, to no avail, to find a picture of these little buggers to post. I have some somewhere but of course I can't put my finger on them.
you are correct,I fat finger it.
E9UZ9B307A
E9UZ9B307B
Ed
Old 10-27-2008, 06:23 PM
ncranchero's Avatar
E9UZ9B307A
E9UZ9B307B
Ed
It happppppppens!
Old 10-28-2008, 06:38 PM
Thanks all. I give er' a try in the next week or two.
Mike
Old 07-04-2011, 07:24 AM
bent-1 bent-1 is offline
bent-1 is starting off with a positive reputation.
... Adding to an old thread, Dorman in their OE Solutions line makes these as replacements for the 5/16" (800-007) & 3/8" (800-008) fuel lines. The kit containing both sizes is 800-017 is handy when changing fuel pump or dropping the tank as you get both pressure & return line clips / retainers.
They list them for line sizes 10.5mm (fits 5/16" coupler), & 13mm (fits 3/8" coupler). NAPA had the best price at $3/ three pk. The numbers are easily found on part store websites.
Old 07-04-2011, 09:01 AM
ncranchero's Avatar
Good info, thanks!
Fuel filter retaining clip/o-ring placement timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 1 12-10-2013 06:54 PM
352 Timing Mark Gregory Glaser FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 09-02-2012 08:38 PM
broke fuel filter retaining clips - 07 expy trpltongue 2007 - 2014 Expedition & Navigator 9 05-06-2010 08:24 PM
Fuel filter replacement- I broke the retaining clips Blowinsmoke 2007 - 2014 Expedition & Navigator 5 09-27-2009 05:18 PM
fuel filter - 96 Ranger - changing jb8897 Ranger & B-Series 7 07-08-2006 01:18 AM
Tags
14, 2004, clip, clips, dorman, e9uz9b307a, e9uz9b307b, f150, filter, ford, fuel, install, line, replace, retainer, retaining
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
