est time to clear fuel lines / injector of B100
Old 10-27-2008, 04:35 PM
TXHillCountry's Avatar
TXHillCountry
TXHillCountry is offline
With the colder temps coming on, was curious about something. Assume I'm running B100 (which I am ), and now it's about to get seriously cold overnight. If I go add some regular diesel to achieve a more "cold-adverse" mix, how long do I need to run the truck to have the new mix in the fuel tank make it through the fuel lines and injectors ?
Thanks,
TX
Old 11-19-2008, 04:57 PM
cookie88's Avatar
cookie88
cookie88 is offline
Not long. It will mix as you're putting it in the tank. I'd say a matter of minutes based on my observations mixing a little two cycle oil into the fuel.
Old 11-19-2008, 08:59 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
It can't get THAT cold in Houston.......... I blend down to B-80 and don't have a problem to about 10 deg. If I think it's going below +10, I mix it down to B-50.
mudsmokinstroker
05-11-2014 04:26 PM
TourqueRise
15
11-01-2010 10:31 PM
powerstroker100
15
06-14-2010 02:30 PM
Miller
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-14-2008 09:00 AM
digracer
12-21-2005 08:10 PM
Quick Reply: est time to clear fuel lines / injector of B100
