Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-27-2008, 12:47 PM
73F100*8Mile 73F100*8Mile is offline
73F100*8Mile is starting off with a positive reputation.
2.9 Intake coolant leak #2
1990 ford ranger w/ a 2.9. I installed rebuilt heads about 2 years ago and they're absolutely great. Truck runs great w/ no hickups but when i first put the heads on and ran it, i put about 5,000 miles on it and the coolant gauge would always climb to OT and then drop about halfway between OT and cold and then come back up again. Then i noticed the coolant level would drop very slowly over time so i eventually threw another intake gasket in there after seeing it was leaking out the back of the intake. Now it leaks even worse and i was very careful to torque to specs and use mega black silicone and so forth. Whats the deal? Any ideas? I've considered the possibility that the heads i received were re-surfaced to the point that my intake doesn't seat like it should now. Any tips?
__________________
1973 F100 390 C6
1990 Honda Accord
1968 Hardtop Mustang I6 200
1977 E-150 351w
1968 Fairlane 302
  #2 (permalink)
Old 10-28-2008, 10:52 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
I would put a pressure tester on the cooling system and pump it up, with the engine off and 15-17psi in the sytem it makes it very easy to see and hear exactly where the leak is coming from. Do you still have the old gaskets you just replaced? If so, look at them carefully to see if you can spot from the compressed areas just how they lined up on the heads and intake and you may be able to tell from that how the intake was situated on the heads. Look closely around the water passages as well. It may indeed be neccessary to have some material removed from the intake to drop it down a bit, Any way to find out how much was removed from the heads two years ago?
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #3 (permalink)
Old 11-09-2008, 06:14 PM
capridude capridude is offline
capridude is starting off with a positive reputation.
Are the heads re-done stock Ford heads?
If so, eek! They may have warped more since install.
What brand of gasket are you using?
Be careful of using silicone sealers, they can damage HEGO sensors.
Jeff
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
