Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-27-2008, 01:55 AM
madclone's Avatar
madclone madclone is offline
madclone is starting off with a positive reputation.
2.9 hydro lifters QQ
Got a couple of questions
First: how should I judge hydro lifters condition? I took them apart, flushed thoroughly all the inner parts with gasoline. Then I loaded them with kerosene and tried to squeeze them. By hand they definitely feel rock-solid, you know, like trying to squash a bolt with bare fingers or so. Then I used the thing on the photo (what’s a correct English term for it?).
With this thing I squeezed them all right, but still they displayed huge resistance and I could do only one turn at a time, then wait a couple of seconds till it bleeds and make a turn more etc. For reference (just in case) Kerosine is heavier than gasoline and lighter than diesel fuel. I thought I could try using a mix of kerosene and motor oil to simulate the hot motor oil viscosity, maybe I’d get more evident results.
Second: how do I reload them before assembling the engine back? Are there any tricks?
If I just put oil inside #1, then insert #2 and using a thin screwdriver I can depress the valve #3. This makes possible #2 to travel fully in #1, with some oil still remaining inside #1. This what I did to test the lifters. For final assembly the tricky part is that we have to put thing #4 in place and lock it with a spring #5. Oil that remains inside won’t let do this. Any ideas?
Last edited by TigerDan; 10-27-2008 at 09:34 AM. Reason: Cleaned up extraneous code
  #2 (permalink)
Old 10-27-2008, 01:58 AM
madclone's Avatar
sorry for all the fonts mess above.... +
imported text from Word and it gave all this...
  #3 (permalink)
Old 10-27-2008, 09:42 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of TigerDan has much to be proud of
I cleaned up the mess...
First, the thing you used to compress the lifters is called a C-clamp. Second, you would want to have them completely clean and free of oil before reassembling them. You want to look for free and easy movement of the piston inside the lifter when you depress it, and make sure it travels all the way back up by spring pressure when you release pressure. Then, put a reassembled lifter into a container that you've filled with clean motor oil and depress/release the inner piston a few times till it refills with oil and firms back up, then put it straight into the exact same lifter bore that it came from.
If you have mixed them up, you'll have to throw them out and buy new ones (which is what I'd do anyway).
__________________
FTE Moderator
Stop by and see us in the
Northern California Chapter!
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
  #4 (permalink)
Old 10-27-2008, 09:52 AM
madclone's Avatar
Thanks!
Nope, did not mix them up. As for buying new ones - well maybe two or three of them. I want to assemble it, do some welding on body, a little paint and way it goes to some new lucky owner ))
I've started looking for a big Bronco, but here in Russia they are mostly in very poor condition and the price is usually over $7000, so I don't know. Anyway, if my B2 stays with me, it's better to find a "new" engine from European Ford Scorpio. Prices range from $200 to $500 for a rather fresh engine.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
