Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Minnesota Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Minnesota Chapter Join Chapter, Leader: fordpower88
  #1 (permalink)
Old 10-26-2008, 07:26 PM
Framy Framy is offline
Garage is empty, add now
Framy is starting off with a positive reputation.
jframstad
blended diesel fuel
Ok as you will be able to tell, I own my first diesel, 08, 6.4. Question on diesel fuel. When do I need to worry about putting in #1 diesel? Can you trust the stations that say they blend it? What ration to they blend it at? If I pull into a station that has #1, #2, at what ratio do I blend it now in relation to the colder temps? Would appreciate info on this, Thanks
  #2 (permalink)
Old 11-07-2008, 09:16 PM
03SUPERDUTYF350 03SUPERDUTYF350 is offline
03SUPERDUTYF350 is starting off with a positive reputation.
here in MN most stations are good at getting good diesel I have never had any problems
  #3 (permalink)
Old 11-10-2008, 05:07 PM
mndiesel's Avatar
mndiesel mndiesel is offline
2006 Ford F-350
My Garage
mndiesel has a great reputation on FTE.mndiesel has a great reputation on FTE.mndiesel has a great reputation on FTE.mndiesel has a great reputation on FTE.
If I remember correctly the 07 and up should be run on ULSD only which is diesel #1.
__________________
Tom
06 CC Dually 6.0 SOLD
99.5 f-250 7.3 SOLD
07 VW Eos
SOLD, lol
http://www.roadsidehelpnetwork.org/
  #4 (permalink)
Old 11-26-2008, 11:26 AM
HP junkie's Avatar
HP junkie HP junkie is offline
2004 Ford F-250
HP junkie has a very good reputation on FTE.HP junkie has a very good reputation on FTE.HP junkie has a very good reputation on FTE.
The stations have a chart they follow regarding the blend of diesel. It depends on the time of year. The later in the season (colder) the more blended it is. #1 diesel is winter and #2 diesel is summer diesel. I usually run the #1 in the coldest month (Jan.), otherwise I run 50/50 blend of #1 and #2 slowly turning back to straight #2 by spring. I have not had any problems of gelling, but I also add Power Service with every tank. The 2007 year trucks and newer need to run ULSD. The stations have until 2010 to switch from LSD to ULSD, although most have made the switch already. I hope this helps (a little late, but I check in when I can).
__________________
Cory
'04 F250 6.0 SRW CC LB 6-speed 210K, Edge juice w/attitude, open exhaust, blue spring.......
'05 Freestyle Limited 3.0 CVT 109K
Tags
blended, diesel, find, fuel, minnesota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
