Fuel clog?
Fuel clog?
The last time I had the fuel filter housing and FPR off, there was a bunch of crud in the bottom of filter bowl as will as the black bowl on the bottom of the FPR. Here is my question, if i was not able to get all the crud out of either bowl, could it possibly cause a clog somewhere else in the fuel system? if so, where should i check? I have cleaned the screen from the inside of the bowl, but don't know where else to look.
Thanks
Thanks
Rick
The next time you have the bowl out you really should try to get all that crud out of there. That junk usually contains moisture that eventually leads to corrosion / pitting and if the pits get large enough the bowl will leak. Once you get it all clean a coat of J-B Weld will extend the life of the bowl if the pitting has started.
I understand how the fuel flows, but was more concerned wrether the FPR could get clogged and cause a no start. I have it out right now and going to clean everything well. I can keep the heating element out of the bowl, correct?
Rodney, thanks for the JB weld tip, I'm not going to do it this time but will keep it in mind.
Thanks
Thanks
austf350
05-15-2014 06:18 AM
Trapperpete52
21
03-04-2013 06:35 AM
Spktyr
15
12-03-2012 10:13 PM
