Finished the engine rebuild
I finished the rebuild of the 300 six cyl that I am going to put in the 69 N600 this week. I still am looking for the correct oil filter though. I need one the has the nipple on it with threads to screw into the block. Anyone know where I can get one of these?
I get the cab back from the sandblasters on Monday. I should get the frame back on Wednesday. My next goal is to put new brake lines, wheel cylinders, master cylinder, and the booster (hydrovac?) which mounts under the cab. I have no been able to find that part number either. I have ordered a book, but it has not arrived.
Any help would be appreciated.
Oh..I also set up my mig welder this week. I picked up the argon as well. I am going to use it to weld new panels into the cab, but I am going to practice on scrap first.
Just wanted to give you an update.
[/IMG]
[/IMG]
Nice lookin' engine...
Later Man...
Thanks Dave. I did get the 80/20 mix. I still need to hook up the receptacle yet. I will be doing that tomorrow. The sandblaster still has not started on my truck yet. I talked to him this morning and asked him to do the frame first. I will then run new brake lines and such. The hydrovac and master cylinder will be in tomorrow morning to the parts store. The starter and alternator will be done Wednesday. Frank said he was blasting my frame at 9:30 tomorrow and will be done in about four hours. He is then going to paint it in the afternoon. I hope to pick it up Wednesday at 10.00 am. I need to measure the brake drums to see if they are 14" or 15" so I can order the wheel cylinders.
I am ordering the patch panels today. I hope to have them by end of week. Next Monday will be a big day for me I hope to have everything back by then. I will then need to order a new ez wire kit.
Sounds like it is coming along pretty quick. Make sure to use the smallest wire you can for sheet metal. .023 Smaller wire less heat, less heat less chance of distortion. I also like ESAB's easy grind wire. Seams softer and grinds easier - again less heat. Spoolarc Easy Grind
If you have a chance you should cruise the web looking for MIG welding basics videos. utube has a few.
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
