1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Ignition coil sugestion 97 Expedition 5.4
Old 11-19-2008, 04:24 PM
wpmplopez's Avatar
wpmplopez
wpmplopez is offline
i got 160k miles on 6 of the 8 COPs and they are acting up. i have a Standard set on order i trust the name for years. just a note for those of you new to COPs: i was new a few years ago with the 4.6 in my van and now th 5.4 in the excursion. the boots should be the first place to look. you will see white marks where the spark goes thru and there are some deals on ebay for the boots like 8 for 20 bucks with the springs. anoither thing that happened to my excursion is the water outlet under the t-stat broke where the "fetuccinni" gasket goes and it leaked very little but enough to get into the spark pluc hole and screw up the boot. and i gues eventually the COP. one thing i want to ask the group is: is there a way for the COP to be bad and read the right ohms? my haynes manual gives the range for these readings but i think with time they become suseptible to heat.
plo
Old 11-20-2008, 07:08 AM
98expeditionXLT's Avatar
98expeditionXLT
98expeditionXLT is offline
Do search on fellow member "Sequel2Spud" who in a thread titled" 97 Engine misses @ 60 MPH" describes how to throughly test coil packs. There is a little more to it than just measuring resistance.
Old 11-20-2008, 08:45 AM
wpmplopez's Avatar
wpmplopez
I love this forum! great answer. I just want to add that moisture in the hole at least in my case was a leaky manifold gasket. with 160k I can't complain.
Old 11-20-2008, 09:15 AM
alloro's Avatar
alloro
alloro is offline
Received 4,174 Likes on 2,419 Posts
oddfordjunkie
Washington Chapter
195
04-14-2017 08:23 PM
the winemaker
08-12-2016 05:26 PM
thelonerangerxlt
Exhaust Systems
03-12-2007 09:31 PM
thelonerangerxlt
Oil & Lubrication
01-12-2006 02:21 PM
Quick Reply: Ignition coil sugestion 97 Expedition 5.4
