Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-24-2008, 08:41 PM
E100PU E100PU is offline
E100PU is starting off with a positive reputation.
'61 front door hinges
My lower drivers door hinge needs replacing. Are the upper and lower hinges repro'd by anyone for 1961's? Part #'s ?
Any info is appreciated.
BTW...eBay has listed a 61-67 tailgate. It was around $800 this AM. Seller won't say if it's the 19.5" or the 23.5". (Thank you ND!)
Thanks!
  #2 (permalink)
Old 10-26-2008, 10:27 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw is gaining momentum as a positive member of FTE. 66gpw is gaining momentum as a positive member of FTE.
Dennis Carpenter sells new door pins for these old girls. I got a set from him for my truck. Parts # B-7022840 My catalog is quite outdated fromthe late 80's. The pins then cost a $1.50 ea.then.
They did not come with bushings. The doors were pin against metal. So your door hinge maybe wore and need to be reemed ourt for you to put a bushing in for anew pin.
The pins tend to wear beforethe doors hinge. Made of asofter metal.
Macs truck parts may have pins also. As I said the pins more than anything wore before the hinges.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
86 F150 Exploere XLT Ext cab
66 Merc 1Ton Flat deck
78 F250
  #3 (permalink)
Old 10-26-2008, 09:44 PM
66gpw,
Yeah, my '03 Carpenter book listed only the pins and attaching bolts, but I didn't think it would be that simple. (?!) The door drops off the latch by less than a 1/8" when opened and closing, it's definitely out of alignment.
Thanks for the input!
  #4 (permalink)
Old 10-27-2008, 12:11 AM
66gpw's Avatar
It sounds like it needs to be honed out for a brass bushing to be put in for the new pins. This will help straighten it out. My door the pins were wore into.
Where to get bushings from I do not know, maybe Macs.
Thelater vans and vehicles in the 70's had bushings added to help lessen the wear.
It still happens, but less frequently.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #5 (permalink)
Old 10-27-2008, 08:38 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
1961/67 Econoline Front Door Hinges
The following hinges are Genuine Ford NOS = New, Old Stock Originals ~ Not Reproductions.
All these hinges fit 1961/67 Econolines.
C1UZ8922800C .. Right & Left Upper Hinge (LH = reverse hinge pin)
Green Sales in Cincinnati OH has 9 = 800-543-4959
Wesley Obsolete in Liberty KY has 4 = 606-787-5203
Freese Motors in Monticello IA has 1 = 319-465-3541
C1UZ8922810C .. Right Lower Hinge
Green Sales has 12
Wesley Obsolete Parts has 2
C1UZ8922811C .. Left Lower Hinge
Green Sales has 5
Ed Bennett Ford Obsolete Parts in Lebanon PA has 1 = 717-272-8762
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #6 (permalink)
Old 10-29-2008, 08:27 PM
Thanks for the info ND & 66!
  #7 (permalink)
Old 11-04-2008, 08:03 PM
61eline 61eline is offline
61eline is starting off with a positive reputation.
hinges
I recently purchased new door hinges from green supply.made from much thicker stock than my original hinges.they can be ground down to size local econo pickup guru told me they were van hinges not pickup.dont see where that would make a difference butjust passing on info.
  #8 (permalink)
Old 11-06-2008, 07:33 PM
61eline,
Yeah, it really doesn't make sense Ford would make two different hinge sets for the E's. Especially in that era of manufacturing. Did you contact Green about the fitment issue?
  #9 (permalink)
Old 11-08-2008, 08:34 AM
Ford Parts Guru
Quote:
Pickup hinges are exactly the same as van hinges.
Tell you Econoline "guru" to get himself a parts catalog and look 'em up.
If they were different, I would have said so in post #5.
The hinges Green Sales sells are originals, as no one reproduces these parts.
The upper hinge is a right side, you need to reverse the hinge pin when using this hinge on the left side.
The instructions that say to do this have been in place since 1961, as Ford never sold a left upper hinge.
__________________
  #10 (permalink)
Old 11-08-2008, 09:22 AM
tin-man's Avatar
tin-man tin-man is offline
SC Chapter LDR
1975 Ford F-250
My Garage
tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE. tin-man has a great reputation on FTE.
Bill, I finally bought me a cd from hipoparts for my 1975 F-250 Hi-Boy, now I will be able to find some parts by myself. I don't know if they know you are not, but I told them you recommended them.
__________________
David
1975 F-250 Custom High-Boy
Join the SC chapter HERE
Master Slacker#14
True compassion puts love in action
  #11 (permalink)
Old 11-10-2008, 09:00 PM
Thanks Nd
Thanks for the info ND,The hinges were definately original didnt come with pin reversal direction but that wasnt to hard to figure out.Im not sure why they the hinges were thicker but I had to grind them down to get them to fit hinge slot in door Mick
  #12 (permalink)
Old 11-11-2008, 01:56 PM
tin-man's Avatar
SC Chapter LDR
1975 Ford F-250
My Garage
Welcome to FTE and have a good time with it!!!
__________________
David
Master Slacker#14
  #13 (permalink)
Old 03-11-2009, 11:14 PM
Ford 67 Ford's Avatar
Ford 67 Ford Ford 67 Ford is offline
Ford 67 Ford is starting off with a positive reputation.
I replaced pins in a couple doors, they were pretty frozen but sprayed penetrating fluid for a couple days then punched them out, now they're just right.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
