Thoughts on rear end oil change
hey guys,
Just picked up some Mobile 1, 75w-140 syn gear oil to do a rear end oil change this weeked.....The bottle states it works in both convential rear ends and in limited slip rear ends. Any thoughts regarding the need for an additional friction modifier?...
Thanks
Thanks
click here and watch the videos in the first post, that is my thoughts on what oil with no modifiers that I put in my truck.....
also when i replaced the rear end oil for sells the rear end diff cover for an 08 super duty for just over 50 bucks, it is aluminum with fins to help cooling (if you dont think you need cooling tough your rear end after driving just 20 miles unloaded) you will need to get longer bolts (I got them from lowes)
on
1 Post
DieselManor - Ford Sterling Differential cover heres a pretty good deal from diesel manor.
The FM and lube go in the same way.
