Stone Colored Models - Ford Truck Enthusiasts Forums
Old 10-23-2008, 10:23 PM
enggass enggass is offline
enggass is starting off with a positive reputation.
What I found out today... Got a 2006 Lariat recently and when I bought it I was informed the color was Stone. (Two-tone with Arizona Beige). I have also seen others on here mention Dark Stone. Well today I was decoding my vehicle sticker in the door jam, and the codes I got for color were T7 AQ. I then looked those up at PaintScratch Touch-Up Paint Code and Paint Name Search and what I came up for the 2006 F150s was: Charcoal Beige Metallic (T7) and Arizona Beige (AQ). I confirmed this at another look-up site as well. There was no mention at either site of any Stone color besides a Smokestone Metallic (HG)
Not that it matters, just interesting...
Steve
Old 10-24-2008, 10:05 AM
canstacker canstacker is offline
canstacker is starting off with a positive reputation.
06 Xlt says Dark stone clearcoat on window sticker with the arizona beige clearcoat accent. Not sure what the paint codes are but you could say it looks charcoal beige metallic...see pics in gallery.
Old 10-24-2008, 11:14 AM
Looks the same as mine... I'd be curious as to what your color code is.
Can be found here:
http://www.ford-trucks.com/article/i...r_Decoder.html
Old 10-24-2008, 11:24 AM
Here's another paint chart...
Colors
Old 10-24-2008, 12:00 PM
Buck 1 Buck 1 is offline
Buck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to beholdBuck 1 is a splendid one to behold
My '08 is Stone Green, but the touch-up paint is an earth tone color. Matches perfectly.
Old 10-24-2008, 01:10 PM
03redstx 03redstx is offline
03redstx is starting off with a positive reputation.
my 06 was Dark Stone, my '08 is Stone Green with arizona beige accent...color looks exactly the same on both
Old 10-24-2008, 01:14 PM
soundwave's Avatar
soundwave soundwave is offline
soundwave is starting off with a positive reputation.
Is this the same "stone green" color that Ford Rollled out the current Explorer model with? I think it looks great with the AZ Beige two-tone on the F150
Old 10-24-2008, 01:44 PM
Quote:
no its looks more brown than green, but there's a lot of metallic in it...its a sharp color
Old 10-24-2008, 08:30 PM
kenwowski kenwowski is offline
kenwowski is starting off with a positive reputation.
I have a dark stone 07' and recently bought touch-up paint
dark stone = charcoal beige...same code/same color but different names
dark stone is NOT the same as stone green which is about two shades LIGHTER than dark stone
hopes this helps!
when you go to the parts department ask for charcoal beige because dark stone is not listed
Old 10-24-2008, 10:37 PM
WhlM1's Avatar
WhlM1 WhlM1 is offline
WhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant future
Dark Stone is one of the best colors Ford has ever offered. I got it on my 08 F350.
Old 10-25-2008, 12:42 AM
wb6anp wb6anp is online now
wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.wb6anp has a very good reputation on FTE.
hopes this helps!
the color looks awfully close to the 08 Stone Green.
Old 10-25-2008, 08:09 AM
you are right they are VERY close but when you put them next to each other there is a difference and you can see stone green is just as nice but a couple shades lighter
Old 10-25-2008, 09:28 AM
2005FX4SCREW 2005FX4SCREW is offline
2005FX4SCREW is starting off with a positive reputation.
I work in a GM parts department so I can only speak for the generic, but I looked at my touch-up paint list. Under the color name, there are 2 colums. 1 is the 'engineering description' and the other is 'marketing description.' As best as I can figure, the Ford people had 1 name for the color (Charcoal Beige Metallic), but the marketing people thought it may be too much so they changed it (Dark Stone) to be more appealing and easier to market. On my list there is no mention of 'metallic' in any of the marketing descriptions but it's in most of the engineering ones. You best bet is to go off the paint code on the sticker to get the correct thing.
paaint codes from 2000 to 04 deck60 1999 to 2016 Super Duty 0 11-17-2014 10:37 AM
quick factory paint link i found. roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-11-2014 01:13 PM
Touch up paint coverup Fatstrat Paint & Bodywork 4 06-29-2013 02:23 PM
96 F250 - Paint code/color? Giftman23 General Diesel Discussion 0 12-21-2008 12:16 PM
Those of you with Dark Stone Metallic boxcar1974 1999 to 2016 Super Duty 24 01-31-2006 10:55 PM
Tags
08, 2006, 2008, beige, charcoal, code, dark, f350, ford, green, metallic, paint, stone, t7, touch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
