Rapid Blinking Turn Signal - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 10-22-2008, 06:52 AM
nd925 nd925 is offline
nd925 is starting off with a positive reputation.
Hey guys, has anyone come across this before. When I turn on the left turn signal it flashes about twice as fast as the right one. The right one flashes normally as it always has. Could this be the turn signal relay going or something else? Anyone pinpoint the whereabouts of the relay? I'm guessing it's under the dash somewhere. Thanks in advance for any help.
Old 10-22-2008, 07:08 AM
pgw85706 pgw85706 is offline
pgw85706 is starting off with a positive reputation.
Usually a burned out bulb.....check that first.
Old 10-22-2008, 07:43 AM
Thanks for the quick reply. I did check that, both the front and back signals work, just flash much quicker than normal. Could the bulb still be an issue even if it flashes?
Old 10-22-2008, 08:13 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Yes, the bulb can still flash and be at issue. And I agree, it's probably a bad bulb. You can also pull them out and check for moisture and corrosion in the sockets and harness connectors.
Old 10-22-2008, 10:08 AM
Bear River Bear River is offline
Former ******
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Also, if you use LED bulbs, they will flash more rapidly.
Old 10-22-2008, 11:47 AM
Slim Shady Slim Shady is offline
Slim Shady is starting off with a positive reputation.
I had that problem on my expedition, and I thought the bulbs, too. They al looked good, but I replaced them anyway, but I still had the problem. It ended up being the flasher module itself.
Old 10-22-2008, 12:14 PM
Thanks for all the input. I'll start with the bulbs and go from there.
Old 10-22-2008, 02:17 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
It can also be caused by a short in the wiring on that side. The more eletrical load the faster the flashing.
Old 10-22-2008, 03:52 PM
hydro_37 hydro_37 is offline
hydro_37 is starting off with a positive reputation.
Either a bulb or flasher would be my guess. Both cheap fixes anyway.
Old 10-22-2008, 06:50 PM
Peter94's Avatar
Peter94 Peter94 is offline
Peter94 is gaining momentum as a positive member of FTE.Peter94 is gaining momentum as a positive member of FTE.
Also, if you have a trailer wiring harness, be sure to check that. It actually has a module on it. It went bad on our 94 ranger, and we had all sorts of problems.
Old 10-23-2008, 02:15 AM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Had the exact same problem on my 95 Taurus, but the emergency flashers worked normaly.
If yours is wired the same as my Taurus, it will have a single electronic flasher which operates flashers & turn signals & if the emergency flashers work fine, the multifunction switch is probably the culprit.
Thats what the problem was on my Taurus
Old 10-23-2008, 11:19 AM
Should have mentioned that the way I knew the multi switch was bad was to simply check the resistance thru the switch.
In the right turn circuit there was no resistance equals good.
In the left turn circuit there was high resistance which equals a bad switch.
50 bucks for a new switch & a couple minutes to install it & problem solved.
As the other guys mentioned the fast flashing is caused by high resistance somewhere in the circuit. Find that & the problem goes away.
Old 10-24-2008, 07:39 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
That happed on my 02 jeep wrangler and I had water in the turn signal which blew the bulb. Replace the bulb and sealed the lense, worked normal.
Only one turn signal Adam Woolridge 1961 - 1966 F-100 & Larger F-Series Trucks 4 12-07-2015 04:31 AM
Turn signal dash light alecs 1961 - 1966 F-100 & Larger F-Series Trucks 2 06-28-2015 09:39 PM
Right Turn flash issue Rudog 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-15-2012 12:35 PM
Intermittent Fault: Turn Signals stop working when brake is depressed. Totoro 1997-2006 Expedition & Navigator 2 04-19-2011 06:23 PM
turn signals immastrokinnow 1994.5 - 1997 7.3L Power Stroke Diesel 4 10-24-2008 09:27 AM
Tags
2003blinks, blinking, escape, expedition, fast, flashing, ford, left, mariner, mercury, ranger, rangerturn, rapid, signal, signals, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
