Aftermarket trans oil pans?
You could install a drain plug in your pan, which whenever i get around to changing the fluid in mine, i'm going to install one aswell.
The oil drain plug I seen, you had to drill a hole into the bottom of the pan and then install the plug.
Mr. Gasket 4470 - Mr. Gasket Transmission Drain Plugs - summitracing.com
I have this one, it's got a drain, and is good quality.
Transmission rebuild kits and parts - AOD/AODE/4R70W - AOD/AODE/4R70W deep aluminum transmission pan - DirtyDog Performance (Powered by CubeCart) - Cast aluminum Pan
