Wipers Again 88
Wipers Again 88
Well I though i got it fixed by opening up the governor control box and soldering the board.Now only high wiper works no low or delay.To top this off it has worked great for about three weeks till it started to rain then its back to this. WTF Why does this wiper have a mind of its own? any help?
Isn't it fun???
Now that it's raining, you're using it more and it cooked the board again.
I even went so far as to replace some resistors with higher wattage ones,..and used heat sink paste.
Was it just a cold joint, or did you find something burned on the board too?
Finally caved and bought a new one.
But this time I just wrapped it in foam rubber and tucked it in there.
What a pain to get out!
But yes, that switch will plug into the harness after the intermittent wiper governor and you will have high and low speeds.
ArlyDude
12-14-2014 09:32 PM
c66miller87
05-15-2012 03:40 PM
