Fuel rail problem and removal?
I recently replaced my HPOP and truck was running well. Even more recent, my turbo quit working and I noticed Diesel dripping down the back of my motor. I took off the valve cover and found the stainless braided hose that connects the fuel rail to the motor to be leaking on both ends. In other words, My fuel pressure is low and my oil is being thinned by the diesel. I also noticed white gummy oil on the inside surface of the valve cover but not all over the rockers. I drained the oil to make sure there is no head gasket leak and there was no water in the oil pan or in the oil. How could the white film have gotten on the valve cover? Also, how do you remove the stainless hose that runs from the fuel rail? All this work is getting old and I can use all the help I can get to make the work as easy as possible. This truck is not only breaking my bank, it is also breaking me. my truck is an 03 with 110,000 miles on it. I purchased the truck at around 80k. Never had any problems until one day my HPOP just gave up on me. The fuel rail seems like a very easy fix, just need to know how to remove the hose. Thanks
Keith
Keith
To remove the pipe/hose, you have to open the fitting. A special tool would be recommended to do it, but you can create something. The main thing is you have to move the plastic ring towards to the hose side, and you have to do it evenly to make sure it opens, but I doubt that this will happen without taking off the oil rail.
By the way, you probably won't have any water in the oil if you have hg failure. I just did my head stud job a few month ago, almost all of the cylinders were leaking in to each other, puking coolant big time, but not a drop of coolant in the oil.
I had not worked on diesel until I replaced my HPOP. The fitting that is leaking is the one that is on the rail.It is the rail that is directly under my valve cover on the passenger side of the truck. It appears the rail is held on by 8 small bolts. Should I head to ford dealer to pick up o ring for injectors or is there a better means of getting them? Also, on the braided hose, is it o rings on the hose that are bad or o rings on the rail that are bad? I will know for sure tomorrow but any information is appreciated.
http://www.backglass.org/duncan/ps60...l/ps60_027.jpg
This is your fuel ...
http://www.backglass.org/duncan/ps60...l/ps60_040.jpg
and this is your high pressure oil system. If you are leaking at the oil line than that can't be fuel. You couldn't even see it's leaking, only if you run your engine and you have a visual on it. But if you do, that would mean you have a major HP oil leak, and your injectors wouldn't fire. So that makes me think ( because mentioned that you know, see that you leaking fuel ) that you have some damaged injector O ring, that's why the fuel leaks back to the valve cover.
In this situation you have to pinpoint which injector leaking, pull it and I think you end up faster if you just get the O ring at the dealer...
quaddriver
07-13-2023 08:19 AM
Talltruck
10-26-2015 11:09 PM
