Glow plug relay wiring diagram - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-21-2008, 01:51 PM
IM1096's Avatar
IM1096 IM1096 is offline
IM1096 is starting off with a positive reputation.
Question Glow plug relay wiring diagram
Does anyone know where I can find the wiring diagram for the glow plug relay on an early 99 PSD? I'm not sure if mine is wired correctly..... As always, thanks in advance for the info and support
Old 10-21-2008, 02:10 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
I'll post this link to help but I'm not sure if the early '99's are the same as the rest.
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Look at the picture caption "Remove the Old GPR"
Old 10-21-2008, 02:34 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Here's my cheat sheet jpg.
Old 10-21-2008, 02:53 PM
Smokin''s Avatar
Smokin' Smokin' is offline
Smokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant future
'99's are the same. Only difference is lack of AIH relay.
Old 10-21-2008, 03:13 PM
Hit it!
Quote:
Good to know, thanks.
Old 10-21-2008, 06:30 PM
IM1096's Avatar
Thanks for the pic, mine is very similar. With the ignition on, the "#3" wire has positive voltage, which would be contrary to it being a ground through the PCM??????
Old 10-21-2008, 06:53 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
I hope this helps
85 is red
Old 10-21-2008, 06:55 PM
PaysonPSD's Avatar
Quote:
3 & 5 could be reversed and the relay will still operate. With key on you will see battery on both with one lead to ground. You will be reading the voltage through the winding. You need to lift the wires off the posts to isolate them and then read their potential with key on.
Edit: Nice diagram Jim. Does what I said make since?
Old 10-21-2008, 07:00 PM
megawatt00's Avatar
Yes it does Robin, A coil dosen't know the difference between positive and negative. They are sometimes marked just for the sake of keeping things the same.
Thanks!
Old 10-21-2008, 07:36 PM
IM1096's Avatar
Thanks for the diagram and info, helped me understand it a little clearer,,,,,, As always this forum is a wealth of great info and help!!!!
Old 08-14-2014, 06:20 PM
subcaptian subcaptian is offline
subcaptian is starting off with a positive reputation.
Sorry in advance for the necropost, but on this page, http://api.viglink.com/api/click?for...d%20Web%20Page , On the diagram "Remove the Old GPR", what is the purple wire on the output terminal?
Old 08-14-2014, 08:40 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Quote:
Originally Posted by subcaptian View Post
Sorry in advance for the necropost, but on this page, ... On the diagram "Remove the Old GPR", what is the purple wire on the output terminal?
That wire goes to pin 8 of the PCM (Glow Plug Monitor). Somewhere along the way there is a fusible link and wire changes color to White/Lt Grn.
Glow Plug Relay Fuse Question mneves2000 1999 - 2003 7.3L Power Stroke Diesel 4 11-03-2016 08:00 PM
Many issues with the 6.9 lilraven96 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 12-13-2015 08:22 AM
Starter Relay on Fender? scotttahoe 1999 - 2003 7.3L Power Stroke Diesel 14 10-20-2015 07:45 PM
glow plug wiring diagram olyellow 6.0L Power Stroke Diesel 1 03-28-2013 09:40 PM
1990 7.3 l Glow plug relay wireing diagram RodneyH 1987 - 1996 F150 & Larger F-Series Trucks 2 01-03-2011 03:58 PM
Tags
73, 85, 99, aih, ca, deisel, diagram, ford, glow, plug, plugrelay, plugs, powerstroke, relay, remove, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
