2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
code reading?
Old 11-02-2008, 01:19 PM
threefiftyone's Avatar
threefiftyone
threefiftyone is offline
code reading?
Is there a way to get into the OBD-II without a code reader?? I know on some late model vehicles, the techs can navigate the codes within the CPU by just sequencing the correct buttons. Such as sequencing the buttons for cruise control. I've seen it done on my 2007 International 4700. My check engine light/emissions light is on in the Expy. Trying to avoid the dealer
Old 11-02-2008, 07:44 PM
whimsey's Avatar
whimsey
whimsey is offline
No! You have to use some sort of code reader for OBDII. You can purchase these Code Readers at Walmart for around $100 or less. Maybe less somewhere else. "Supposedly" you can get "free" reading at AZ or AAP.
Whimsey
Old 11-03-2008, 05:45 AM
chuck s's Avatar
chuck s
chuck s is offline
Was this before or after swapping mufflers?
-- Chuck
Old 11-03-2008, 08:31 AM
threefiftyone
After. I ordered a K&N drop in too. When i went to pick it up, the box had been tampered with and it was the wrong filter in the correct box. So they ordered another one. Relevant? Well the old filter was pretty bad, and i had to put that one back in. After that is when the light came on. So, being an emissions light, i assumed putting the bad filter back in was the culprit. I checked all connections and it is still on.
Old 11-03-2008, 10:35 AM
berry1234's Avatar
berry1234
berry1234 is offline
Possible the MAF sensor got oil on it from the K and N.
Old 11-03-2008, 03:21 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
If you are considering a code reader, might as well by the Scangage, it reads and clears codes as well as all the cool monitoring components.
Old 11-03-2008, 07:42 PM
threefiftyone
-sorry if i wasn't clear, i never took the K&N out of the wrapper because it was the wrong one. Is the MAF sensor the one plugged into the intake just after the filter? Like i said, the old one (paper) was pretty bad, (oily) and had to put it back in. IF oil did get on it, how do i go about cleaning it? Thanks
Old 11-05-2008, 08:36 PM
threefiftyone
well, i had the code read today, and it came up as a emissions code in the intake. The tech (not ford) said that it was probably the MAF sensor. Apparently some of the emission system is covered by a 5 year, 50,000 mile warranty, and some of it is covered by an 8 year 80,000 mile warranty. Other than my extended warranty. Next stop: THE DEALER
02f300
09-21-2013 09:58 PM
jdadamsjr
6.7L Power Stroke Diesel
06-16-2012 01:42 PM
ddraper
1983 - 2012 Ranger & B-Series
09-26-2010 07:37 AM
redwood
1997 - 2003 F150
10-28-2009 02:51 PM
Quick Reply: code reading?
