Dome light wiring, anyone have a diagram?? - Ford Truck Enthusiasts Forums
Old 10-21-2008, 08:47 AM
reamer's Avatar
reamer reamer is offline
reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.reamer has a very good reputation on FTE.
Hi All
I have a '76 Bronco. On the Bronco, the "Dome" lamp is powered only by a switch on the light itself.
I would like to install door switches. Can anyone post a complete wiring diagram showing Dome light, door switches, and headlight switch, and complete wiring?
Is the bulb in the dome a single filimant or double (1 for the manual switch, one for the door switches?
Thanks
Reamer
Old 10-21-2008, 11:16 AM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Hi reamer,
The '76 Bronco is actually a different style Bronco than the 73-79 pickups and 78-79 Bronco's, so it's unlikely you'll find any wiring diagrams for your year in this forum. However, check out the 66-77 Bronco forum:
http://www.ford-trucks.com/forums/forum45/
In general though, you run constant power to the switches, and then switched power up to the dome light. You could do it with a single filament bulb if you run both switched and constant power up to the dome light. I can tell you the wire colors for a 73-79 pickup, but I don't know how that would translate over to a first generation Bronco.
Dome / Interior light override help Andrew010 6.7L Power Stroke Diesel 5 09-12-2012 08:51 PM
51/52 Dome light wire diagram John Morton 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-16-2012 12:33 AM
'55 F100 dome light wiring Joe T. 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-08-2011 06:29 AM
1957 dome ligh wiring mkrog 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 09-29-2011 10:01 AM
79 dome light wiring colors/diagram V10Crew 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-28-2010 04:13 PM
Tags
2001, 2005, 73, basic, curtousy, diagram, dome, f150, f350, ford, general, light, lights, wirind, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
